Got around to measuring the V8 landrover
Series 2 with 3.9l V8, disco diffs, coils and 32" x 9.5" simex's on 16" rims
Not worn at all
30psi
260mm front and rear. Pretty much the same as safari or landcrusier on 35's
Diff Head Clearance Heights
- Bush Crasher
Re: Diff Head Clearance Heights
interesting! just measured up mine
kzn130 surf
33/10.5/15 Silverstone mt117x brand new
36psi
275mm on rear
285mm up front
only good thing about ifs is tunnel clearance
another thing is the gearbag xmember to concider my og one was nearly lower than rear diff
kzn130 surf
36psi
275mm on rear
285mm up front
1969 Nissan Patrol G60
7.00 x 16 worn SAT front, near new olympic trakgrip rear 30psi
230mm front, 240mm rear
- Suza
LWB Safari Running 33" Savero Mt's half worn @42lbs Front 235mm, Rear 240mm
LN61 surf on swb solid axle hilux chass
cast iron 350 chev + winch and winch bar at the front,
near full 140l fuel tank behind the rear axle
so theres plenty of excess weight hanging off it.
new 35" maxxis mudzillas at 30psi
front 280mm
rear 300mm
front 280mm
rear 300mm
Suzuki sj413
brand new 31x10.5 Federal Cougaria m/t inflated to 30psi
260mm front
260mm rear
260mm front
260mm rear
KZJ78 33"BFG (3/4 worn, 30psi) 260F, 255R.
Compared clearances on a KZJ71 Prado & a FJ70 a few years ago both on 31.5x15 (different brands, but same height):
Prado 230F, 230R,
FJ70 235F, 235R
But the spring pack made big difference ...
Prado 230F, 230R,
FJ70 235F, 235R
Rowan
KZJ78 LWB Prado
KZJ78 LWB Prado
and the prize for the lowest clearance goes to.....
1997 nissan Mistral
Large h233B rear diff.
factory tire size 235/75/15
half worn tires
195mm diff clearance
EDIT and with new Kumho 31" MTs (14mm tread), the diff clearance is 225mm.
1997 nissan Mistral
half worn tires
