Hey All
So after braking 2 rear links I think its time to make some disconnects, rather than taking the bar out (It's out right now and its got a lot of roll) So I found a design I like that is no longer being made, but I have some questions that some of you guys might be able to shed some light upon.
The kit from Rock Stomper http://www.rockstomper.com/catalog/suspen/discon.old shows the design I am after, and I have found the items needed, but I am not sure how beefy I need to make the units.
I figured the pillow ball rod ends can be 10mm ID, and the channel over them would be 2mm steel, attached to a 2mm wall thickness 20mm tube. Would this be strong enough?
Pic for reference
Otherwise if anyone has a better idea please post them up. Even better if someone makes an off the shelf it for around $200 i'm all over it (estimated it will cost me about this in materials to do it my way for Front and Rear)
Sway Bar Disconnects KZN130 SURF
- stovanovich
Re: Sway Bar Disconnects KZN130 SURF
Talk to Sam bro. Sure he could fab something up for you (after all he had practice on Rino haha)
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
Users browsing this forum: No registered users and 30 guests
