Auto-Lockers (Yes / No)
mudlva
Re: Auto-Lockers (Yes / No)
Postby mudlva » Wed Feb 10, 2016 3:46 pm
Unless the 373 nuggets are differant to the 411s then it is only the "bit inbetween" that is fitted. You reuse your cw&p.
That said im not familar with what your vehicle is
00falcon
Postby 00falcon » Wed Feb 10, 2016 4:38 pm
mudlva wrote:If you are going to toss the air con than use that as a compressor with a pressure switch.
Does it ever stop...?
I have started to entertain the idea of using the Aircon pump...
one of the guys in the club has this exact setup...
Driving both his ARBs and onborad air... all with some trick pipes and an old fire extinguisher bottle...
works a treat
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
mudlva
Postby mudlva » Wed Feb 10, 2016 4:47 pm
works a treat
Yip yip yip 8)
TJ
Postby TJ » Wed Feb 10, 2016 4:57 pm
You can't just take the diff head out of a Jeep to regear..... Or fit a locker. Dana diffs don't work like that.
You can fit an elocker which eliminates the whole compressor expense. There are some good options out there without air.
A lot of factory ones now are elocker for simplicity of the control system.
DieselBoy
Postby DieselBoy » Wed Feb 10, 2016 4:57 pm
Sure being a Jeep you can get a Detroit full carrier replacement auto locker for the rear??
We run them in the rear of the Defenders, $1200 landed at your door, fit your self with a socket set and a dial gauge
TJ
Postby TJ » Wed Feb 10, 2016 5:03 pm
You can use thick cut gears for regearing in future. That way you use old locker with new gears. Just double your labour cost, once now and again in future for reinstall.
TJ
Postby TJ » Wed Feb 10, 2016 5:04 pm
DieselBoy wrote:Sure being a Jeep you can get a Detroit full carrier replacement auto locker for the rear??
Probably the most cost effective solution, personally.
yeti
Bruiser
Postby yeti » Wed Feb 10, 2016 5:37 pm
http://www.rockridge4wd.com/
have a good look at what they stock.....shoot em a email will answer questions...have used a few times (ox locker and bits ).....
v8 tj...luvs the gas......
BlakeNZ
Postby BlakeNZ » Wed Feb 10, 2016 6:00 pm
the smallest ARB compressor is about $230 plus freight(v small unit) but basically any 12v compressor will do the job. Even a cheap repco 40 dollar one could be set up to work. The volume of air required to lock the diff is vey low, so even a low quality unit will last ages,as it is far less taxing than inflating a tyre.
TJ
Postby TJ » Wed Feb 10, 2016 6:03 pm
http://m.quadratec.com/products/product.php?pid=16100+1017+07
Eaton elocker. Makers of Detroit lockers.
I don't have them, but its definitely an option.
tweake
Postby tweake » Wed Feb 10, 2016 9:56 pm
BlakeNZ wrote:the smallest ARB compressor is about $230 plus freight(v small unit) but basically any 12v compressor will do the job. Even a cheap repco 40 dollar one could be set up to work. The volume of air required to lock the diff is vey low, so even a low quality unit will last ages,as it is far less taxing than inflating a tyre.
not quite right.
cheap ones often don't handle doing high pressure. they handle tire pressures ok but some are even sold with warning not to go above certain pressures. by mem its a lot lower than what you use for lockers.
by the time you go fixing and modding a cheap compressor you might as well have just bought an ARB.
00falcon
Postby 00falcon » Thu Feb 11, 2016 7:32 am
Cheers guys,
This post played out the way i was hopping...
After all the banter above, i doubt very much i will opt for a front auto locker...
My mind and budget will likely swing the way of a Detroit Locker in the rear... for the time being...
and then depending on lifes other factors, may be one of those gold plated thingies up front... later...
Something along the lines of
http://www.quadratec.com/products/16100_306_07.htm
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-30-Spline-3-73-Down-Automatic-Locker.aspx?t_c=12&t_s=237&t_pt=5589&t_pn=EAT187SL16D
I didn't think replacing the carrier was a home job...?
(with my limited mechanical skills)
O[][][][][][][]O
Eat, Sleep, Jeep...
Clint
Postby Clint » Fri Feb 12, 2016 1:51 pm
00falcon wrote:i have 3.73:1, so i cant get the lockers and then regear in the future if i want to go to 35's...
35's & D30's do not play nicely together. Even D44's are marginal for big rubber.
Rigs I have seen with autolockers in the front have always been good at sliding sideways off the track. Good traction in some conditions though.
I like my Eaton E-locker. No shit on the $$$$ though. I'd like a front one too but that can wait a bit.
Clint
UZJ71 Landcruiser
KTM 640
Cameron
Postby Cameron » Fri Feb 12, 2016 3:40 pm
have yout hought of running one of those cable ox-lockers?
00falcon
Postby 00falcon » Fri Feb 12, 2016 3:46 pm
Cameron wrote:have yout hought of running one of those cable ox-lockers?
My last google was Detroit vz OX... and ARB vs OX
and OX is only US$200 over a detroit (plus the shifter handle)
and my last YouTube was (adjusting Backlash)
i have phoned a few places... and they all seam to say its a days work to install bearing, Carrier, and adjust = Around $700 - $800 + gst
Does anyone have a "Diff Guy" - West Auckland / North Shore (or what have you)
O[][][][][][][]O
Eat, Sleep, Jeep...
yeti
Bruiser
Postby yeti » Fri Feb 12, 2016 4:08 pm
ox does air now as well.......................... :D
00falcon
Postby 00falcon » Fri Feb 12, 2016 4:12 pm
yeti wrote:ox does air now as well.......................... :D
Air...?
or electronic cable actuation....
half the reason to go OX, is to get away from air... isnt it...?
O[][][][][][][]O
Eat, Sleep, Jeep...
yeti
Bruiser
Postby yeti » Fri Feb 12, 2016 4:33 pm
both if I read right ....... :oops:
http://eastcoastgearsupply.com/i-130852 ... pline.html
only reason I did my 30 first is cause I blew the little farker to bits ....learning how to drive the old girl when I got it ..
talk to people did some reading and selectable best bet as sees road time ......so yeah cost heaps but had to go that way...like others say open front lock back watch where ya point it ie driving styles be sweet.... :mrgreen:
would of done the same but hey broke thurdy first...
Petemcc
Postby Petemcc » Fri Feb 12, 2016 6:37 pm
I have autos front and rear in my hilux and had them in my old surf as well. They are great bang for buck. I wouldn't hesitate to have one in the back but would prefer selectable in the front. I wouldn't put one in the front of a full time 4wd. I have a split shifter so can go 2wd low range which is good on longer easy sections. Steering if pretty heavy with it in 4wd With the Lokka in the front
Checkerhead
Postby Checkerhead » Fri Feb 12, 2016 8:15 pm
I keep hearing this, but Sav ran a basically stock (or actually stock?) D30 front end on his jeep with 35" Silvys and never had a diff issue (and won all the bloody competitions). So I guess it comes down to how you drive. Personally I'd still want some thing bigger than a D30.
lax2wlg
Postby lax2wlg » Fri Feb 12, 2016 8:18 pm
The high pinion Dana 30 in the front of the XJ is the strongest D30 they ever made.
Users browsing this forum: No registered users and 29 guests
