currie style sway bar safari rear
slidenyo
Postby slidenyo » Sun May 22, 2016 8:31 am
Bloody saf has a touch of the 100k twitch , so been looking into building a sway bar to dampen it out. Have a real simple plan mount a vw torsion behind the diffhead with the bushes mounted to the back of the upper link mounts then run arms forward parallel with upper links then link with tie rods to chassis. Deranged can you let me know if im going crook in thinking this should work
