24v ARB Air Compressor
This is the big compressor from ARB, it will run your ARB Diff Locks and pump your tyre's up with out trying!!!!
It got it a year ago, fitted it to my Safari for our summer trip up to 90 mile Beach for pumping up tyres when coming off the beach, where it got used a couple of times, and that's it.
It was mounted under the drivers seat so has never seen the mud or water.
Its mint condition, its the BIG ARB Compressor, complete with ARB supplied wiring loom for running air lockers.
Unfortunately, my current truck is 12v, so its just been sitting on the shelf for 6months.
Gutted I can't use it.
Make me a good offer
http://www.trademe.co.nz/Browse/Listing ... =409499653
24v ARB Compressor
24v ARB Compressor
Re: 24v ARB Compressor
can you not change it to 12..? get the bits from arb..?
havent checked new price but i am guessing 300 ish so would you go $150.
muskie wrote:havent checked new price but i am guessing 300 ish so would you go $150.
Try $550 RRP
I will keep it in mind though man
jeez didnt know they were that much, sorry man
muskie wrote:jeez didnt know they were that much, sorry man
Yeah, its really overkill for just pumping up tyre's from!!!
It moves some serious air, I can't remember the Litres per minute, will check. Its pretty huge.
Its really suited to some one that's brought those chinese air lockers and wants a reliable and quick compressor to run them and pump up tyres from.
Or if someone is putting ARB Air Lockers in their Cruiser or Safari and wants to save a couple of hundred $$ buying the big compressor rather than making do with the smaller one that you can't do tyres from.
Hell, I would even swap it for a decent 12V compressor for just pumping tyres up with, my 4 year old Supercrap compressor is getting tired
That is were I'm at really I think.
I have this Blingy compressor that I can't use that's going to waste sitting on the shelf, so would be cool to see if I can either sell it for enough to get a decent 12V compressor, or swap it for one.
Here's ARB's sales pitch off the web site about this compressor:
Heres the tech/spec data sheet for it. Its the CKMA24 compressor:
http://www.arb.com.au/media/products/co ... ations.pdf
Designed to withstand harsh environments, the CKMA24 is installed in your vehicle and includes a full wiring harness with relay, multi position mounting bracket and pressure switch.
Features:
High flow, compact 24V DC air compressor
Designed for Air Locker use, inflating tyres and other equipment
Sealed for moisture and dust resistance
Hard anodised cylinder bore for reduced friction
Teflon impregnated carbon fibre piston seal for maximum trouble free life
Anodised mounting bracket dissipates motor heat and allows compressor to be repositioned 180 degrees
Quality components for quiet operation and extra long life
Constructed entirely of lightweight, high strength engineering grade materials
Over-pressure safety valve equipped
Motor is internally thermal protected against extreme temperature damage
Full wiring loom included for simplified installation and plug-in connectivity to Air Locker control solenoids
Heavy duty maxi-fuse equipped for professional in-line circuit protection
Optional tyre inflation hose kit available separately
Available in either a 12V or 24V configuration
would ya be interested in a swap for the typhoon 150 PSI twin head http://www.4wdbits.co.nz/ProductsList.a ... goryID=151.
i have had it for 2 years but its not done a lot of work.
give us a PM if ya interested
Cheers Tony
Cheers Tony
91 HZJ73 Cruiser, 4.2 non turbo,33 x 12.5 kl71's,UHF radio, snorkle, diff breathers, Factory winch, Awesome club truck.
Badnuz has hooked me up with some bits he had floating around co's he's a good bugger, so fingers crossed with a bit of persuasion I can get it run on 12v and put it to use myself again!!!!!
Cheers Badnuz
Cheers Badnuz
Hi
I have got a 12v compressor Chinese ARB copy. I am fitting a chinese air locker in my safari and need 24v ideally, I also have a wiring loom with arb switches fitted for a 12v system.
If your wiring loom is for a safari and works the diff lock then we may have a perfect match.
Pm me or phone 07 3125770 today or on sunday afternoon.
1991 SWB GQY60 TD42 safari.
DTS turbo kit.
DTS turbo kit.
too late chap, he is converting the 24v one to 12v
