Wrecking one out.
Several parts gone, ask if you are after anything.
YN130 Surf parts for sale.
Re: YN130 Surf parts for sale.
Damn, why is it when someone is wrecking one, I don't need anything haha.
Dont suppose it is a model with aircon? Could use a endless-air system but mine was origainlly carby so never had the aircon mounts on the block
3VILC wrote:Damn, why is it when someone is wrecking one, I don't need anything haha.
Pretty sure it has aircon, I would need to check the spare engine for mounts as the original engine has gone to scrap metal heaven.
Ah bugger..as after thinking about that properly after I posted I suppose I would need the crank pulley too to get the extra pulley that drives the aircon belt
spare motor should have that too..
What do you want for all the gear to convert a carby 3y to injection?
RustySurf wrote:What do you want for all the gear to convert a carby 3y to injection?
What is required for the swap other than the engine parts, manifolds etc.?
Not sure I have everything.
Wiring loom ecu intake manifold injectors fuel rail distributor coil
..exhaust manifold, igniter pack, alternator if you have the old style external reg one
I'll look tomorrow and see what's available for you both. Thanks
what colour is the interior? (steering wheel)
1980 4x4 Hilux Restoration
tintin wrote:what colour is the interior? (steering wheel)
Grey interior. Steering wheel is knackered.
Users browsing this forum: Google [Bot] and 14 guests
