Hey
Keen on a toyota diff
It has to be 6 stud,lsd, drum or disc ,have head in centre,1500mm from flange to flange ,have a ratio between 3.9-4.3
Wanted Toyota diff
True I'm in Auckland but im sure we can sort something,i'dont think it'l matter if its coil or leaf because i'll be making new mounts for the links.Is it LSD,How much you think you want for it ?:D .Also another question how do the handbrakes work on Toyotas because I need to get awayfrom using the back of the trans drum brake like on a Range rover
Users browsing this forum: No registered users and 22 guests
