16x10" 6x114.3 4x4 steel wheels - WHERE DO I FIND THESE?!?
Hey guys
So, have a new Navara on the way (2014, 4wd ST). Wanting to chuck some big muddies on it like my current Surf (15x10" 33x12.5") but I've just found out since 2005 the Navara's do an odd-ball stud pattern (typical) of 6x114.3 not the usual 6x137.9 (or 139.7? Can't remember now!)
The 15's won't fit around the brakes apparently so I have to go 16x10", which is fine, but I can't find any of the black steelies in that size that have my stud pattern
Does anyone know if they are available, and where from?
Otherwise I'm going to have to look at re-drilling (not really too keen), or spacer adapters to take it to the right stud pattern (not really too keen either)
Any help much appreciated
Re: 16x10" 6x114.3 4x4 steel wheels - WHERE DO I FIND THESE?
Only the Stx navara had them, might have to look at aussy
jeffw wrote:Only the Stx navara had them, might have to look at aussy
Hey jeff, not sure what you're meaning?? The ST-X Navara had what?
I'm after somewhere that sells 16x10 black steel 4x4 wheels but in the 6x114.3 stud pattern
Only the stx had that stud pattern, the non stx navaras are normal, hubs might be interchangeable?? Otherwise importing wheels my be the way to go
jeffw wrote:Only the stx had that stud pattern, the non stx navaras are normal, hubs might be interchangeable?? Otherwise importing wheels my be the way to go
Oh - that'd be sweet then if the ST-X has 6x114.3 and the ST has 6x137.9
Is anyone able to confirm this?
bronx89 wrote:Oh - that'd be sweet then if the ST-X has 6x114.3 and the ST has 6x137.9
derk wrote:bronx89 wrote:Oh - that'd be sweet then if the ST-X has 6x114.3 and the ST has 6x137.9
I've just called Nissan and although they couldn't tell me what the stud pattern(s) is/are, they said that the ST and ST-X 2014 Navara have the same ones.. you can take a wheel off one and fit it on the other
Conflicting information coming from all corners!
- KIWI_TERRANO
All the d40s so stx rx st have same pattern, you can buy adaptor spacers to make it to the older d22/21 stud size, have seen pic from aussie of after market steelies on d40s
Maybe they've changed them then, I know of a guy that had an st and an stx that couldn't swap rims between due to stud pattern
jeffw wrote:Maybe they've changed them then, I know of a guy that had an st and an stx that couldn't swap rims between due to stud pattern
The first I heard of it was since 2005 all Navara's went to an odd-ball stud pattern of 6x114.3
The guy you know, what years are his ST and STX?
that's a yank pattern, Ford/hennessey Raptor, Dodge viper/durango/Dakota,Toyota tundra/tacoma all run that pattern, Pretty much all japanese car makers that sell trucks in the continental north america ........something to do with US saftey standards for vehicle's that fall into certain parameters calculated on wieght/power/ towing etc.
D40 (badged a frontier /xterra and also as a xtra cab branded suzuki) was designed for left hand drive market primarily, Oceania other smaller markets second. hence the stud pattern.
Crash bandicoot wrote:that's a yank pattern, Ford/hennessey Raptor, Dodge viper/durango/Dakota,Toyota tundra/tacoma all run that pattern, Pretty much all japanese car makers that sell trucks in the continental north america ........something to do with US saftey standards for vehicle's that fall into certain parameters calculated on wieght/power/ towing etc.
Thanks for confirming although not the information I wanted to hear
Chinese but they have them by the looks of it.
http://www.china4x4offroad.com/product_largerimage.asp?id=7447
churchill wrote:Chinese but they have them by the looks of it.
Hah they do too! Only 8" wide though, and shipping would be crazy. Hmm
Where are you located, have you thought about trying a wheel repair place that does steelies? they might be able to come up with something as they flip centers as a normal thing, in Christchurch we have royce clive and elite wheels that i know of
trucked wrote:Where are you located, have you thought about trying a wheel repair place that does steelies? they might be able to come up with something as they flip centers as a normal thing, in Christchurch we have royce clive and elite wheels that i know of
Hey, located in Auckland. Oh ok hadn't thought of that. Flip centers; is that removing the centers and welding new one in? Anywhere you know of in Auckland that does this? Cheers!
Cheers bud have emailed the steel surgeon will await his response
Checked out the tardme listing - can source way cheaper by importing them but with the smaller center bore does that matter if the wheel I'm wanting to use has a 110mm bore hole?? Also the thickness will have to match the length of the standard studs in order for them not to protrude and stop the wheel from sitting flush when bolting on to the spacer?
28mm makes them non warrantable
bronx89 wrote:Flip centers; is that removing the centers and welding new one in?
More or less yes, sometimes its the same one just flipped for offset changes, but removed then welded in again.
Crash bandicoot wrote:28mm makes them non warrantable
No, it doesn't.
They are wheel adapters, not 'spacers' so can be certified.
Been there done that with 30mm.
Ralfie wrote:Crash bandicoot wrote:28mm makes them non warrantable
No, it doesn't.
new rules first hit on google for the LVVTA ..
a vehicle fitted with any wheel spacers or adaptors needs LVV certification. The maximum thickness allowed is 20mm ...
you will have to go ROH i think out of aussie, dealer here in nz may be able to get them,
Crash bandicoot wrote:new rules first hit on google for the LVVTA ..a vehicle fitted with any wheel spacers or adaptors needs LVV certification. The maximum (spacer) thickness allowed is 20mm ...
edited to help avoid confusion.
Adapters 27mm max (with exceptions allowing for larger in some circumstances)
- skid
- Tyre Man
LOL as I sit here and read this thread I cannot believe nobody has questioned the fit of these massive wheels to the Navara.
Most 10" wide wheels are -44 offset and placing these on a factory Navara without a massive lift will incur huge steering issues as you will find you can hardly turn the wheel before they rub quicker than a 12 year old schoolboy from the 80s perving at his poster of Sam Fox
Chur. I am running back to my corner now with my large tub of popcorn
Not to mention the fact that you'll be going through wheel bearings and rack ends quicker than a two dollar hooker.
Xterra's completely different. They are based on the D22 Navara/Frontier chassis. They're essentially all the same chassis.
Have had offroad trucks before so the lift is obvious, it's the wheel stud pattern issues I'm wanting information on
I'm getting a 3" suspension lift in the Navara
Correct the 10" wheels will have a -44 offset, same as on my Surf at the moment
Might wait for the Navara to arrive then go fit up some adapters/spacers and 16x10's and see what thickness I need to clear the studs for the wheels
Man what a mission to get the 4x4 steel wheels onto a damn Navara!
Users browsing this forum: No registered users and 41 guests
