winch swap.plus need cruiser wheel studs
hi guys ,am back on my 40 and need some bits .am changing the discs on the rear and somehow in the 4 years since i started coiling the back i have lost my wheel studs.any cruiser drum brake hub will do ,need 2 hubs also am taking the pto winch of it and want to change to electric.can get a new supercheap one for less than 500 but thought there must be something better sitting in peoples garage that they may want to swap.depending on what winch am offered have choice of 2 pto units,a standard single gear or a dual gear forward/reverse unit (which are super hard to get hold of and worth good money by themselves).ptos to suit split transfer ie later 40,60 or 70 cheers sig
Re: winch swap.plus need cruiser wheel studs
I've got some studs in the shed off the old Prado diff, disc brake though so might be different... will take a pic for you tonight. Failing that wheel studs should be in stock at your local Toyota dealer for only a few bucks each.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
cheers clint ,think i have the studs sussed .now just need someone to swap my winch .cheers sig
Users browsing this forum: No registered users and 35 guests
