Any one have any hydro fan parts for a 1uz? After both pump and motor but specifically the pump
Cheers alistair
Wtd 1uz hydro fan bits
Re: Wed 1uz hydro fan bits
Disregard previous edit .
The pump is separate from water pump . It's a big ugly thing wit a big smooth pulley for the back of the serpentine belt . It might be just as easy to make one yourself with a car oilpump gears and 3 plates.
The gears inside are the lobe gears as opposed to vane gears like a ps pump . Could just over drive ps pump with a smaller pulley and use half the flow for fan .
If I was evergoing to do it I figured if run it off the ps pump or some other solution .
Apologies for putting ideas in your mind that might not be as easy as they first sounded .
They are separate to the water pump...water pump is driven from cambelt..
Hydropump is driven from the accessory serpentine belt
Re: Wtd 1uz hydro fan bits
Bump..still on the hunt.
Cleaned the shit out mine but still no good
Users browsing this forum: No registered users and 33 guests
