1992 LJ71 Prado Parting out
I have an LJ71 prado I am parting out.
Has a 2LTE with approx 350xxx kms, starts first pop and runs fine. (on trademe)
https://youtu.be/kD9F_DUIP5Y for vid of it running.
Still in truck.
5 x Rims with Simex 32 x 10.5 x 16 inch rim. About half worn.
Front diff and steering box sold.
Manual gearbox, driveshafts and clutch system gone... (I am keeping them)
Brake booster and MC plus pedal box under offer.
Drop me a PM or ask here
Open to offers on most parts so if you want something suggest a price you want to pay and we can go from there.
Calvin
Still in truck.
Calvin
Re: 1992 LJ71 Prado Parting out
how bad is the rust in the rear side window trims/seals, and do you reckon you could get them out in one piece? i need both sides.
also after a heater control box for mine, and the trim panel around the radio (got the circular vent in it, middle of the dash above the heater controls)
sorry, they're probably the two worst bits to get out of the body haha.
mfrsr wrote:how bad is the rust in the rear side window trims/seals, and do you reckon you could get them out in one piece? i need both sides.
ahhaa will take a look over the weekend. and get back to you....
Calvin
Man, a sweet running 2L-T - wouldn't be too many of those left in the wild
What are the doors like?
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Doors are dented and pretty much munted.
Barn doors are ok ish.
Engine being pulled this week. (sold)
Plan is to lift body off chassis and start gutting it.
Body will get cut up and off to scrappy.
Best feature is the roof and bonnet. Both with minimal dents.
Will strip out interior electrics.
Passenger seat is ok... Drivers one is broken.
If there is anything you want just ask....
Rear axle housing and diff available 4.88
Front axle housing available.
Alternator (with vac pump)
Starter
Power steering pump.
ECU
Speedo cluster.
Starter
ECU
Speedo cluster.
Do you still have the Electric Hubs ?
oldblue wrote:Do you still have the Electric Hubs ?
Sorry I got it with spacers and aftermarket hubs...
Does it have the factory electric adjustable shocks in it still??
Keen on those if it does, the yellow Munros I got are way to hard!!!!
No factory shocks.
Has black kyb's in the front and some yellow things in the rear.
Engine and simexs sold.
Front diff gone.
Heap of stuff listed on Trademe
http://www.trademe.co.nz/Members/Listin ... mber=12674
Front diff gone.
mfrsr wrote:im still after the heater controls if youve got em.
Hey bro, out of interest is it because ya heater fan is only working on full speed and nothing else??
If so I can tell ya how to fix that for a couple of $2 parts from Jaycar and 10 mins with a soldering iron. Simplest fix on the planet, and pretty satisfying too haha
Not undercutting ya sales Mr Kbushnz !!!!!
hahahah not worried about sales .... Fix sounds interesting ... tell us all more !
DieselBoy wrote:mfrsr wrote:im still after the heater controls if youve got em.
nope, the old plunger style heater tap seized up and i snapped the pivot on the control in the dash. been stuck on hot for about 5 years now...
i swapped the tap for a newer corolla one when i had the heads off the 1uz last time, i just haven't got around to replacing the control box. the fan still works on the top 3 settings so i reckon im pretty lucky haha.
i would still be keen to know how to fix it though, my daihatsu truck's fan only works on full.
kbushnz wrote:I have this. 40 bucks.
sweet. definitely.
its the same as mine. i think my cables are still good so you wont need to stuff around unthreading them from yours.
I'll do thread for it, fixed 3 of them now, so getting good at it!!!
mfrsr wrote:kbushnz wrote:I have this. 40 bucks.
sweet. definitely.
Check yah inbox. Message sent.
Users browsing this forum: No registered users and 29 guests
