Cromoly tube
nivaman
Cromoly tube
Postby nivaman » Mon Aug 06, 2018 11:29 am
I am in need of some cromoly tube.
Size is
9.500" long, .750" outside dia, .188" wall thickness.
Where is the best place to buy it from?, has anyone got a piece in these dimensions?.
Thanks.
kbushnz
Re: Cromoly tube
Postby kbushnz » Mon Aug 06, 2018 12:55 pm
What part of the country are you at?
MihiT
Re: Cromoly tube
Postby MihiT » Thu Aug 16, 2018 7:54 pm
Why chromoly? Which chromoly? Would stainless work? What's the application? a 12ga pistol? are any of the given dimensions optional, ie are you just matching existing, or could it have thinner wall? Does it need to be seamless?
A bit pedantic, but specifics never hurt...
4140 is prety common in engineering situations, 3/4" OD should be stock, but that's pretty heavy (and odd size, you may find 1/4") wall. I'd go and have a dig through a boatbuilder/coachbuilder/fabricator's scrap bin. If you find something near size then a few minutes on a lathe will get you on spec. But then it may need heat treating or stress relieving depending on the application...
Clint
Re: Cromoly tube
Postby Clint » Wed Aug 22, 2018 1:30 pm
https://cardwells.co.nz/4130-molytube-benders/chromoly-4130-tube-0-750-od.html
Cardwells have a good range of cromoly tube, looks like .156" might be the thickest in 3/4 though. They used to sell by the foot, give them a call.
Clint
UZJ71 Landcruiser
KTM 640
Craydiver
Re: Cromoly tube
Postby Craydiver » Tue Aug 28, 2018 8:39 pm
These guys stock whole range of CrMo tube, sell by the foot.
www.afwe.co.nz
afwenz@xtra.co.nz
20 Andrew Baxter Drive,
Mangere, Auckland,
New Zealand.
Phone: (09) 275 4850
Users browsing this forum: No registered users and 1 guest
