Wtb bj74 speedo cable for a automatic
Mat13
Postby Mat13 » Mon Dec 17, 2018 10:07 pm
As title apparently can't get new ones for a auto. If someone knows somewhere to get one new would be good otherwise will buy second hand
kbushnz
Re: Wtb bj74 speedo cable for a automatic
Postby kbushnz » Tue Dec 18, 2018 5:30 pm
mudlva
Postby mudlva » Tue Dec 18, 2018 6:28 pm
they would be the same as a manaul just a little bit longer at a guess, that said the 5 speed box is similar to a auto. the connection is in the tranfur box rear output housing and that can be rotated so if its a bit tight you may find moving by 60d might be all it needs
Mat13
Postby Mat13 » Thu Dec 20, 2018 8:15 pm
yeap the manual cables 300mm shorter than the auto, I did run the auto one straight through to check length and had a fair bit of slack but not sure if it would be enough. Managed to find a place locally that does new inners so gone that way.
Users browsing this forum: No registered users and 37 guests
