Wtb bj74 speedo cable for a automatic
As title apparently can't get new ones for a auto. If someone knows somewhere to get one new would be good otherwise will buy second hand
Re: Wtb bj74 speedo cable for a automatic
try https://www.aucklandspeedoservices.co.nz/index.html
They can make a new inner....
- mudlva
they would be the same as a manaul just a little bit longer at a guess, that said the 5 speed box is similar to a auto. the connection is in the tranfur box rear output housing and that can be rotated so if its a bit tight you may find moving by 60d might be all it needs
yeap the manual cables 300mm shorter than the auto, I did run the auto one straight through to check length and had a fair bit of slack but not sure if it would be enough. Managed to find a place locally that does new inners so gone that way.
Users browsing this forum: No registered users and 18 guests
