Hi team santa came early and I have some long field axles coming for the rear of the lux. I am after a couple of spare rear hilux axles or even just studs and bearing holders so i can fit the new axles up and swap them out minimising the time the truck is in the garage.
Once I'm done I can return what I borrow with the axles / studs and bearing holders That come off my truck.
I'm in qtwn but will be up chch for Xmas.
Pete
Wanted to borrow - hilux rear axle
Re: Wanted to borrow - hilux rear axle
Haven't you done the surf wide axle rear swap? If so I have one sitting in the shed.
Yip I have but either a surf or hilux one would work as I only actually need the bearing retainers and wheel studs as I have new axles so axle length no problem. You coming up central over the break? Will have you a call.
Pete
Pete
Bump. Still looking
To be clear I want to fit bearings and seals to my new axles before removing the old ones from my truck so that the truck is only out of action for a couple of hours.
To do this I need to get hold of bearing retainers and wheel studs. Then I can get the new ones all sorted and just swap them out.
Even just the bearing retainers would be a help.
Pete
Pete
Ive got a couple ln130 length ones, if u have anyone near morton mains
Cheers stu that should do the trick. Will get in touch when I get back down south
Cool away over new year then again mid jan to canterbury, but can leave somewhere for u if im away
Users browsing this forum: No registered users and 9 guests
