1996 LN107 FS 7k
catalystracing
1996 LN107 FS 7k
Postby catalystracing » Sun Jul 02, 2017 10:00 pm
Not really wanting to sell, but life has thrown a curve ball at me and I need to sell my yellow beast.
WOF till 18/10/2017
Reg till 16/7/2017
Rucs out by about 300ks
270xxx ks, water pump, timing belt etc done at 232xxx.
Rear wheel bearing and seals done couple months back.
Front wheel bearing replaced couple years ago.
Diff breathers
Front and rear brakes done
LED instrumentation lights
Rear Lokrite Lokka
Rancho 9000 series adjustable shocks
Standard 3l 2.8 motor non turbo
G52 G/Box with replacement cluster 2 years ago.
Kingstar A/Ts, new on front, 1/2 worn on back on 15 x 8s
Replaced center bearing and rear universal, though the uni made need replacing again shortly. Been through a couple even tho they get greased, seems to be a Toyota thing.
I have new glows to put in will try this weekend if not sold prior, new owner can have them.
New 780 CCA battery.
Rear spring hangers have new nolathane bushes.
Replaced front sway bar D bushes.
R32 Skyline front seats.
All ball joints and tie rod ends have been replaced.
Asian Manual locking hubs
New front hand brake cable
New speedo cable
Fenix Alloy radiator
Extractors.
Needs:
Steering pump replaced/serviced, its leaking. I do have a spare but no time to swap it out.
Wheel alignment.
Exhaust has leaks that have just started.
Tray is tired, the tray door falls open occasionally.
It has plenty of bush trophies and scrapes. I have owned for the last 7 years and know the owner who had for 10 before me.
Front bar and LED lights/winch NOT included.
Open to swaps but base line is I need 4k cash and the balanced to be negotiated.
Users browsing this forum: No registered users and 30 guests
