Clints Cruiser Project
Clint
Post by Clint »
Mattman wrote:Wicked skills guys. Nice solid acheivement in a weekend.
Are you going to waterproof any of the engine electricals for the motor?
Matt.
Yep I'm pretty rapt, it's amazing what you can do when you have all the required skills & equipment on hand. Mike & Klem are pretty talented, not only can they make cool stuff, they can do it bloody quickly.
I'll probably just spray all the electrics with silicone & soft-seal the connectors, that worked well on the 4AGE in the Zuk. The wiring is pretty well shielded from splashes & We don't do quite as much river work here in the North as you Southerners do.
Yep, the pipes are awesome, Klem put a lot of work into shaping them to allow for future 35" tyre installation :twisted: I was just going to have the extra muffler detachable by exhaust clamp - I doubt they'll look twice at that.
Clint
JTop
Post by JTop »
There is a Big Block 40 in Wgtn, known as The Truk, which has/had a switch under the throttle pedal to electrically open the dumps on full throttle.
J Top
Mattman
Post by Mattman »
As an earlier poster said those manually/electrically adjustable/openable exhaust valves will not pass a WOF from what I have seen.
Pipes with a side exit and a cap should be okay I would have thought.
Anyone else know?
SupraLux
Complete Bastard
Post by SupraLux »
Very nice work... I like it. And fast too... Theres something to be said for having everything you need assembled before you need it :) Might look into that concept... one day :D
Steve
Clint
Post by Clint »
Got into the side bars in the weekend. Klem had put in a plate for the front mount while he was doing the exhaust:
I made up a rear mount & Mike migged it on:
Bars all done. Stuff like this can be a bugger cos it always pulls when ya weld it then doesn't bolt up nicely but these came out alright.
The test:
Seems strong enough.
Then I took off the bumper & started thinking about how the winch & bullbar will work:
Clint
SupraLux
Complete Bastard
Post by SupraLux »
Thats all looking really good... although I suggest making the front risers for the bar out of something a little more solid... those will flap about a lot when you get up to speed :lol:
Did you weld nuts to the back of those plates then drill 4 holes in the chassis for the nuts to slip through?
Steve
Clint
Post by Clint »
SupraLux wrote:Thats all looking really good... although I suggest making the front risers for the bar out of something a little more solid... those will flap about a lot when you get up to speed :lol:
Steve
Thanks Steve,
That's just a pattern, I work at a panel mill so I was thinking of using 25mm MDF for a bit more ridgidity :P
The plates were all drilled & tapped. The rear ones were drilled & tapped right through into the chassis. The good thing doing this at the same time as the engine conversion is that this sort of stuff can be done no worries (by the right person) 'cos it can all go on the cert plate.
Played around with winch & bar stuff a bit last night & Mike gave me a hand to start making some mounts. The fairlead will sit at most 50mm out from where the original bumper was.
Clint
Rangielux
Post by Rangielux »
Steve
Paper is really hard to weld too :lol: hehe
All shit aside, it looks good - carry on :!:
Clint
Post by Clint »
Got the bullbar & winch mounts mostly tacked up. Going to pull it off this weekend & weld it up properly:
The 50x3 flat to wrap around the uprights should be here next week, so once thats on I'll be able to paint it then I'll bolt on an alloy skid panel under the winch & the job will be done. It looks like we may have to trim the bottom tank on the radiator to fit the PTO shaft though.
Clint
UZJ71 Landcruiser
KTM 640
bundymonkey
Stropper
Post by bundymonkey »
Fistly nice work with the conversion in a weekend.
I am looking at doing the same conversion in my LJ70 Bundera so if you dont mind I have a cople of Qs.
How much room was left either side and front of the motor?
Are you running a thermo or do you still have the engine fan?
Did you use the factory radiator or haveyou upgraded it and if you kept the original have you had any overheating issues?
And finally if you had used a front or rear sump would you have had the issues with it hitting the diff?
Thanks
Andrew
Clint
Post by Clint »
bundymonkey wrote:Fistly nice work with the conversion in a weekend.
Thanks
Andrew
G'day, To answer your q's:
There was heaps of room either side. The closest parts were the steering box & the power steer pump. As noted the firewall needed a couple of taps to give clearance behind one of the cam covers.
I'm using the original 'cruiser radiator, shifted about 15mm forward (easy) with the cap socket soldered on in the middle. The original shroud was modified to fit around the 1UZ's factory viscous fan. It stays cool no problem even at low speed & high revs in the bush. Haven't tried it in really hot conditions though.
Mike's experience is that the 1UZ engine fan gives the best result - most electric fans don't really cut it offroad.
I think with a front or rear sump you'd probably still have to cut out a corner to make them fit. We didn't have any lying around to compare with though. I could take some pics from underneath so you can see the placement if you like.
Clint
UZJ71 Landcruiser
KTM 640
bundymonkey
Stropper
Thanks if you could send through as many pics as possible cheers
square_bears@hotmail.com
Thanks
Andrew
SupraLux
Complete Bastard
Post by SupraLux »
Actually, post them in here as thats more useful to forum members than insividualy emailing them all over the place :)
Steve
wjw
Post by wjw »
I may want to do this to my LWB prado soon so any info posted would be great... also a PM of the costs would be wonderful :D
Who knew Prados could fly?
thommo73
Newbie
Newbie
Post by thommo73 »
what gearbox did you mate it to, and what size was the flywheel
Clint
Post by Clint »
It's still got the standard R150F gearbox, mated to the modified lexus bellhousing via an adapter plate.
Not 100% sure on the flywheel size, I'll find out. It's as big as you can go using the 1UZ ringgear & still fitting in the bellhousing anyway. It's made to fit a Nissan Skyline RB26DETT clutch assembly & a modified toyota thrust bearing.
Clint
UZJ71 Landcruiser
KTM 640
thommo73
Newbie
Newbie
Post by thommo73 »
thanks, i'm trying to mate my motor to a h55f out of a MWB landcruiser (11inch clutch), but no one seems to have done it/ or willing to share info.
anyway thanks
Thommo
Clint
Update!
Post by Clint »
I've been pottering away quietly on the cruiser for a bit. I got the front bar finished & painted & the winch mounted up:
I had to make up a bracket to mount the rear of the winch to the front x-member, move the lower radiator hose to the other side & put a notch in the bottom of the radiator to fit the PTO shaft through. There was already a factory notch in the x-member.
As the pto driveshaft was for a cruiser with the std 'porch' out the front I had to shorten the driveshaft a fair bit. The driveshaft mounting brackets were welded onto the chassis, one had to be modified slightly to fit. I also had to make up a flange to attach the shaft to the keyed shaft on the winch industries pto box.
I had the remains of the PTO selector lever mechanism that we had butchered up to put on Klem's comp truck, so I made up a new bracket & linkage with some of those bits & weka'd the 4wd lever off the FJ40 parts wreck. The previous owner had had a PTO setup in it but had removed so I cut a slot in his blanking plate for the lever & made up a catch to prevent inadvertent operation.
I roped it up with the cable I got with the trademe winch which was in quite good nick & there was plenty of it, then it was off to Taupo Rigging for a hook & the job was done.
I winched a dead tree over with it in the weekend & It seemed to work well, have to organise a mission somewhere for some more rigorous testing now :)
Clint
UZJ71 Landcruiser
KTM 640
NJV6
Post by NJV6 »
That bar looks awesome. It's a credit to ya.
wopass
;-p
Post by wopass »
i think i heard the north island safari calling your name :wink: labour weekend :D
Clint
Post by Clint »
Cheers Guys,
Don't look too closely NVJ6, It's my first big project with a mig, I'm a bit tidier with a stick welder but the mig is so fast in comparison. I reckon it'd look a bit better if it was narrower but I wanted it the same width as the body.
North Is Safari? That makes 4 different things I want to do Labour wkend, Mum's 60th is one of them so I don't have much option there.
Clint
UZJ71 Landcruiser
KTM 640
Clint
Post by Clint »
Hey Thommo, the flywheel is 300mm diameter, sorry about the belated reply.
Clint
UZJ71 Landcruiser
KTM 640
WACKO
Pyro
Post by WACKO »
how are you finding the sumitomos? wear and traction wise?
wjw
Post by wjw »
Thats the sorta bar I want to make, except with the bottom tubes recessed under the front bodywork. Did you use the existing Mounts?
Clint
Post by Clint »
Hi Guys
The Sumitomos seem to be doing alright. Traction wise they're pretty good, much as you'd expect being a fairly open pattern for an MT. I've only got a few thousand k's on them & the wear looks OK but it's hard to tell. At near 1/2 the price of some of the brands that are known for their durability I'm not too worried :D
The bar is just mounted to the chassis rails. Once you pull off the old bumper you're left with the 2 bare rails sticking out, they're full of holes with captive nuts & there's nothing much in the way so it's real easy. Cut out your uprights, drill 4 holes in each, bolt 'em on & build from there. Be aware that they don't sit quite paralell due to the angle on the chassis rails.
I was tempted to cut off the lower front trim, indicators & the front of the mudguards under the level of the headlights & do away with the lower horizontal bar but decided it would be a bit much dicking around.
Clint
UZJ71 Landcruiser
KTM 640
Moriarty
Post by Moriarty »
Conan wrote:
a man could waste a bit of time on that website
true that :shock: missed the fact its suppose to be advertising ..... well advertising for profit i mean :lol:
peow peow :D
Damn near went blind, had to go and have a cold shower......
bookmarked the site just in case.....
Clint
Post by Clint »
Got rid of the useless electric hubs last week, put on some hilux hubs with the good strong Aisin free wheeling units. I took a few pics & I'll write up a bit of a how to article next week as there isn't much info out there on what parts are needed etc.
Clint
UZJ71 Landcruiser
KTM 640
wjw
Post by wjw »
Did you use adaptors?
Clint
Landcruiser Electric to Manual Hub Swap
Post by Clint »
Toyota Manual Hub Install: LJ71 Landcruiser
The stock electric hubs fitted to the LJ71, & several other Cruisers, are crap & if you've got some that actually work, enjoy them while they last cos it wont be long before they give up the ghost if you are actually using the vehicle for it's intended purpose. At least carry the right torx bit & driver so you can take off the cover & manually engage them in an emergency.
Fitting manual hubs involves a bit more than just buying a set & bolting them on however so I thought I'd note down what I did to assist others. If you've got the skills & tools to adjust your front wheel bearings, you're well capable of doing this job.
The problem with the electric hubs is that the wheel hub is shorter, so there is no room behind a free wheeling hub for the locknut assembly. Fitting a spacer is possible but not very strong. One solution, developed by Oldblue, is to fit a sealed manual drive to the outside of the electric hub - operated by an allen key. The solution I decided on was to use some Hilux parts & fit standard Hilux Aisin hubs.
Hilux hub on left, cruiser on right.
Parts Required:
Wheel Hubs from a beam axle Hilux, free wheeling hubs of your choice, wheel bearing lockrings & nuts, front spindles (optional), sealant, Loctite.
I picked up a whole front axle assembly off Trademe for $200. Mine was mid 80's vintage but as far as I know all beam axle Hilux's have the same parts. Look for one with the factory Aisin free wheeling hubs, they're pretty strong & don't stick out too far. Get something steel rather than aluminium at any rate. If you've got any bearings, seals etc in the front or in your donor hub that need doing, obviously now is the time for that also.
Tools Required:
The only tools needed that some may not have are a couple of Torx bits; #20 & #40. The best thing I've found for the circlips on the axles is the cheap interchangeable head circlip pliers which come with a head with a couple of 'paddles'. You can use a screwdriver or 2 but flicking the clip across the workshop into a pile of junk never to be seen again is a PITA at times.
Procedure:
Put the vehicle up on axlestands & remove the wheels. Unbolt the brake calipers & tie them up out of the way.
Unbolt the old electric hubs, take off the circlip, remove, then undo the lockring & take off the wheel bearing nut. Fish out the outer bearing race. With a bit of wiggling the hub should pull off.
The old Hilux disc will most likely be solid, the Prado brakes are vented. You need to remove the disc from your old hub. The studs go through the disc & press into the hub. To remove the studs find an old wheelnut you don't like to thread onto the studs before you bash them out with a FBH. Some discs also have a couple of bolts holding them on. Put your original discs on your new hub & press or FBH the studs back in.
As far as I could tell the original hub spindles would work with the new hubs. However I decided that the Prado spindles with the conductors for the hub drive running up the centre & the extra slots in the end for the brushes, didn't look as strong as the Hilux ones I had on hand. I took off the brake backing plate & original spindles, cutting off the wires that feed into the spindle. I took out the axles while I was there & packed some fresh grease into the CV's & all around. A healthy dollop of RTV was required to bung up the hole where the wires went in, & also a smear of sealant around where the spindle bolts on.
Then It's a simple reassembly job using the new bits, greasing as we go, & checking the condition of any old bearings & seals that are going back in.
After setting the wheel bearing preload I locked the nuts with some screw-on type lock rings that I had, but the hilux bend-the-tab type could be used, or the original screw-on lock rings could be cut down & made to fit.
Then it's on with the manual hubs, making sure they are all lubed & driving in out freely. Don't forget that outer circlip. Use Locktite on all the free wheeling hub bolts & torque them up firmly, they're buggers of things for coming loose. Check them again after your first 4wdriving session on them too.
Put the calipers & wheels back on, pump the brakes up in case the calipers got opened up a bit during removal & you're good to go.
Clint
UZJ71 Landcruiser
KTM 640
bundymonkey
Stropper
Nice work on the build up. I have a Ozy spec LJ70 that I am in the progress of the 1UZ conversion. This is a link to my buildup
http://www.4wdmonthly.com.au/forum/showthread.php?t=11316
