1981 HILUX REBUILD
Re: 1981 3RZ HILUX BUILD
I reckon youd be right without an oil cooler, assuming your meaning engine oil, as for trans oil, your can get a decent, cheap kit from repco, and supprisinly they are pretty good.
Cheers Daniel
Cheers Daniel
surf10 wrote:Im running a small trans cooler with a thermo fan on the back to cool my trans, was goin too get another one to run on my 3rz aswell. got it off summit wasent to bad for price and came with all the fittings, hose and mounting brackets. i can post up a pic of it if you want to see how ive mounted it.
Lynx wrote:I reckon youd be right without an oil cooler, assuming your meaning engine oil, as for trans oil, your can get a decent, cheap kit from repco, and supprisinly they are pretty good.
Cheers Daniel
thanks guys,
its just for engine cooling. i cant go wider than a stock radiator and height wise is bloody near imposible too.
i have googled, lots of phone calls, and PM's on other sites but know one will replie what radiator they are using, and no one can tell me the overall size of a 3rz radiator, only the core size which doesn't help me a great deal when i need to know actual sizes, mainly height wise.
I have tried mocking everything up with a radiator from a 2.8 and that has no show of fitting, width is ok it just the height.
maybe its just christmas and nobody really wants help for a measly
$300+ radiator, i know what shops wont be getting a sale
1980 4x4 Hilux Restoration
I had a similar problem quite a few years ago putting a big block 428 V8 into a muscle car. Cured the problem by re coring the radiator with a "big bore race core". Thats what the radiator guy called it. I don't know if it was his own slang for the product or it is a known core type in the auto industry. Might be worth asking a shop about though as it was successful in cooling the big block while retaining the original radiator dimensions.
If you could get a four core put onto your stock hilux radiator I think you would have plenty of cooling.
Just a note that someone pointed out to me, alloy radiators aren't a great idea for 4wd's even though they look so shiney. Repairs are much more difficult, go copper.
Just something to think about, the overall dimensions of a FJ40 radiator which is a four core are roughly 720mm wide x 750mm high x 70mm thick (off the top of my head not exact). They were good for cooling 4.0L donk (same radiator used to cool 3L desiel).
Pete
Pete
my engine mounts have been moved back about 65mm, im using a deisel ratiator out of a 79-82 hilux because there better then the petrol and fit in the bay well and i havnt had any issues with over heating, only problem i have had is the fan hitting the radiator i have cut a fins on the fan down a bit so they dont hit but i will be putting thermos on in the future i would recomend doing that. i havnt over heated once and i dont think my radiator is very big maybe just thick.
p.s i have **** all room at the back of the motor and only just clear my ratiator so if you havnt moved your motor back enough you wont fit a thicker core radiator
This has helped me somewhat
thanks to gen1lux at http://www.perth4x4.net/forum/index.php
before
after
have since taken the fan off and bought two 10 inch fans
i now have a whopping 135mm for a radiator and fans
new mounts
and will need to fill this gap
after
new mounts
- hosehustler
The 3RZ single cab project I have has a Celica Radiator with electric fan, not true tried and tested yet but project about to take off very shortly, going to be a nice wee single cab when done but LN65 shape.
yours is always a good read
I hate signatures
hay man what year is you motor? has it got the for coil packs or dizzy?
are you able to post up a pic of the label on your computer showing part number and plug pin numbers. Im looking for a manual computer for mine, but from what i can see the american auto computers have an extra plug compared to mine.
any help would be great cheers.
sorry man i just looked at one of the pics and saw it was a coil pack version. can you still post a pic of the comp please?
surf10 wrote:sorry man i just looked at one of the pics and saw it was a coil pack version. can you still post a pic of the comp please?
i dont know if this is what you want but here are a couple of pics for you
Thanks man thats what i was after. now i gotta find a new computer
Excellent thread, I have a 3RZ in my Hilux, not many about really. Are you going Turbo at all ??
SCA Floor Mats , Aftermarket Seat Covers , SCA Silicone Wiper Blades
SCA Tool Box , Repco Air Filter , more to come when budget allows......
Hilux Dan wrote:Excellent thread, I have a 3RZ in my Hilux, not many about really. Are you going Turbo at all ??
thanks, there wont be a turbo in the mix, my main aim is to get it going so i drive it
lifted the body off again tonight and took my new engine mounts off to get some more made to move the engine back a further 20mm so that will be a total of 70mm moved back,
and hopefully no more radiator fitting issues now
so if anyone wants some mint 3rz engine mounts that will move your engine back 50mm give me a pm
just a small update
picked up some new shackles and pins, big thanks to monaro427
and made my first purchase off ebay and in less than a week i had some new door seals delivered
chassis, diffs and springs have been painted. just the u bolts to fit and i will finally have a rolling chassis
after 3 years in bits its finally started to come together,
Its hard trying to remember what go's where and what bolt holds that and the other thing on.
sorry about the crap pics off the phone
looks trick, going to be a really nice truck when its finished
Surface Coatings in Tokoroa painted chassis, springs diffs and associated brackets and fittings for me for a lot less than it would cost me in time and money and im am more than happy with the job done
just have to:
fit steering from p/s box to the diff.
total rebuild of rear brakes, everything inside the drums has rusted and seized and looks horrible.
remove the disks off the front diff and and get the paint off them
find the front calipers and make sure they dont need rebuild
(or considering putting vented disks on the front with some later model calipers)
things i need:
everything inside the rear drums
some later model calipers and disks
fuel tank
still lots more to do but getting chassis painted has given me more inspiration to work on it again and finally give me the reassurance that one day this may actualy drive down the road
just have to:
things i need:
fuel tank
finished off my headunit install into the dash today, all up has taken about
4 hours with heaps off measuring and cardboard templates to make sure i got it right
i think it looks ok
i think it looks ok
need to roll it outside now to wash the dust and bird paint off it
looking flash! going to look better than the day it rolled out of the factory.
surf10 wrote:looking flash! going to look better than the day it rolled out of the factory.
thanks,
it think its going to cost me more than it did when it came off the factory
floor too
Its looking like a very tidy conversion. Very nice
i think i may need some flares
there looks to be enough clearance from the sump
i still need to sort out this little issue
Well the hilux has brakes for the first time in about 4 years
all new pads, shoes, springs and cylinders even the handbrake works,
also fitted gas tank and headlights
Going to refit the engine out of the parts truck just so I can drive it.
It's been to long at least this way it will be running soon and not waiting till if or when we have the money to do it.
Have to replace sump and rocker cover gaskets, needs another oil change.
Fill diffs with oil
Just waiting for my new roof lining to turn up so i can put the windows back in.
Front and rear drive shaft's painted ready for install.
Ordered some new outer tie rods and hopfully here tomorrow so i have steering again.
Engine will be in when truck and engine are in the same place.
Fix and paint flatdeck then refit it.
Getting excited now
Fill diffs with oil
Getting excited now
right when i turn the key it the engine makes a sound i have never heard before
Hopefully the sound of the starter motor engaging.... shortly followed by pistons going up and down??
Cool build - looks awesome.
Jay
Jay
Jay wrote:Hopefully the sound of the starter motor engaging.... shortly followed by pistons going up and down??
Jay
Thanks
Sure is, just a tad loud with no exhaust on though.
just need to fit the radiator so i can run it longer than 30secs
(waiting for the bottom hose to turn up, and fit drive shafts)
bodgy up an exhaust then see if everything turns together
oh and some freash gas so it might run a little smoother
awesome, gona be sweet seeing it running, you have me thinking now, after seeing the ridiculous prices hilux,s are now, i wouldnt mind getting this old school shape and rebuilding it...
you have done a wicked job
Users browsing this forum: No registered users and 16 guests
