Clints Cruiser Project
Re: Clints Cruiser Project
Did some research on sizes etc of my various brake system components, it wasn't really making sense why I should have spongy brakes, so I was suspecting it might just be the master cylinder needing replacement or a rebuild. Then I found a really good article on Pirate 4x4:
http://www.pirate4x4.com/tech/billavista/Brakes/
In that I found the gem of info that for floating caliper brakes (eg the Nissan fronts) you double the piston area to get the effective area. Which is obvious when you think about it The old front brakes were a fixed caliper.... Doing the numbers again it is clear a bigger master cylinder is required. So, an 80 series one is now on the way.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Nice! That Billavista has some awsome tech articles. I used to read them all even for stuff I didnt have on my truck
There's gotta be some rocks round here SOMEWHERE!
After a very busy week of messing around with brakes, flares & a few other little jobs that needed to be done, we were ready for some offroad testing Big thanks to Dan & Karl for helping out with a few things over the last couple of weeks.
I had set myself the target of having the cruiser ready for our midwinter campout at Minginui quite a while ago so it was great to make the deadline & get out for some muddy fun.
The good news is it goes really well! Rides much better in the bush, articulates heaps better but still feels nice & stable, puts the power down well, plus none of the modded bits broke, fell off or interfered
Plenty still to do before cert time buts it's great to know I haven't made any serious screw-ups with the major details of the axle swap.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- Checkerhead
Nice one Clint.
Would have been an awesome weekend out with that crew!
What other bits are you doing before cert?
Just bits & bobs for the cert - get a manual proportioning valve & work on getting the brake feel a bit better, side indicators, probably should replace all the rear suspension bushes, front rod ends will need changing to non-greasable, get a new passenger door. Other stuff I'll be doing soon is side bars/ steps under the doors, a swing-away tyre/MTB carrier for the back, beefier front driveshaft...
Anyone with a Nissan Y60 front driveshaft spare... I'm buying, just need the diff end UJ so a semi-munted one is fine. Would also like to track down a couple of full-size Landcruiser spec slip yoke driveshaft top ends with long travel like the Prado ones - not sure if there is such a thing, maybe on the SWB 70 series with leaf springs.
Have decided to keep the Simexs. The road handling doesn't seem too bad & of course they're pretty good in the bush. So once the toy budget recovers a bit I'll get another on a rim for a spare. Going to have to check with the cert guy on rim width, the tyres say '10" rim' mine are 8" & I've heard of that being an issue for the cert.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Been re making the side bars over the last few weeks, back mounts were in the way of the new exhaust, pax side one was too munted to re use anyway, plus they've always needed a few improvements like another mount point in the centre to strengthen them... What you'd think was a pretty simple job swallowed up a heap of hrs.
With all the mount points in a different plane & various things to work around you can't just measure it up & build them on the bench... It's fit up, measure next bit, bend next bit, cut next bit, grind next bit, check fit, grind some more, (put out overalls that have caught on fire ) check fit, (etc) tack on, take off to fully weld, bolt back on, repeat on next bit, jack it all into place cos it's pulled with the welding....
But all done now bar the topcoat.
Next up is a spare tyre carrier, the back door was feeling the pain a bit with a 33 on it so I won't try hanging a 36 on the poor thing. With the nice solid back bar already there to build off it should be more fun than the side bars to do.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Some good progress on the spare tyre carrier over the weekend. Started with the hinge, Plan A was to use an old trailer hub & stub assembly I had, but the hub turned out to be cast iron so I wasn't going to be welding anything to that. A fossick in the random old bearings box found the old taper roller kingpin bearings from the front knuckles I rebuilt. So it was off the to machine shop to make some swarf & some bearing housings:
Add threaded rod, some pipe, a bend, convert lots of steel into grinding dust &...
Got a plan for the wheel mount bit, still thinking about the latch end. Maybe a car door latch bodged on somehow.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- Checkerhead
Steal a latch off a surf rear tyre mount or something similar?
They have a nice rubber preload antirattle type bit in them. Also means you can put the latch out of sight and just have the release cable in a good place.
RH taillights safe now, will have to make another tyre carrier for the other side to protect the other light
Yep, will have a look at a Surf one today, should get some ideas at least.
Of course it's usually the other, out of sight LH taillight that gets damaged I did think about having a similar setup on the LH & having a bike rack attach to it, but it's just more stuff to dick with to get in the back, so the bike rack will get attached to this thing too.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Side bars painted & installed:
Spare tyre carrier mostly done:
Used a car door latch which seems to work well. The recess in the bumper being the right size for the latch assembly to sit in was a stroke of luck, must have been thinking ahead when I made the rear bar 8 years ago
Getting one of the Simexs onto the mount can be done without blowing a foo-foo valve (just)
Just need to make a socket for a bike rack, & add a couple of gussets & she's done.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- Checkerhead
Very clean bro. Nice work.
Tyre carrier all done & rear bar reinforced to stiffen up where it mounts:
Just need another 36" Simex to go on it now
Next job is to replace the old brake proportioning valve with the manual one & refresh the remaining old flexible hoses with new ones to try & get better feel on the brakes. Going to have to take it for a trip to Taupo sometime soon too so I can borrow Klembo's hoist & install the new transfercase gears.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
how well does it stop with those tyres you usually need a vh40 or vh44 remote booster to get those cruisers to stop and/or get them to pass the lvvta brake test, did that prado come out with a double diaphragm brake booster like the 80 series cruisers?
It actually seems to stop ok, just has a spongy feel in the brakes so that's the first issue I want to sort out. The 80 series master cylinder & a thorough bleed up improved things but they still could be better. In theory the bigger MC should give a harder feel at the pedal.
The Prado doesn't have a double booster but I think an 80 series one will bolt straight on if I need it. (assuming I can find one) Will check up on the brake test spec & give it a go once I've got the new hoses & proportioning valve all plumbed in & adjusted up.
Just remembered that Dan's 70 series passed it's cert brake check last year no problem, & he has a similar setup to me, booster & master cyl, front brakes, tyre size all the same.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Given the diff gearing & tyre sizes are now a bit different from stock the speedo was way out, 100 indicated = actual near 140 So I thought about electronic/gps speedo replacements, DIY little gearbox thing on the cable, $$$ speedo drive correcters... Then had a brainwave & just drew up a new face, printed it out & stuck it on
After working out the increments I drew an appropriate pie chart on an excel spreadsheet then pasted the image into MS Paint to tidy it up & add the numbers. No doubt there would be other ways to skin the cat depending on what software you've got but that worked pretty easy for me. Looks factory
The Cruiser gauges aren't actually backlit, they are lit by reflected light from the surround, so still all good for night ops.
Will check against the GPS but the calibration shouldn't be too far off. The dash is pretty easy to pull off if I need to stick on another face to get it right.
Currently working on the brakes, have manual adjustable proportioning valve now installed instead of the old load sensing one, just waiting on a few new brake hoses to hopefully get the stopping side sorted.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
OK I'll bite, what's / ? ! C / mean?
well way I read it ? means.. hey you have past the 180 mark better slow down.. ! means holy shit mate.. slow down.. and well C means you're gonna crash.. Nice idea about the face plate.. might do the same..
Well I've always thought it stupid when car makers put 240 km/h speedos on grandma's 1600cc hatchback so I couldn't bring myself to put numbers on this that it'll never do. ? & ! can be whatever you like, c is 1079252848.8 km/h of course, weren't you paying attention in 4th form science I also considered WTF - OMG - LOL
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- Checkerhead
Clint wrote: c is 1079252848.8 km/h of course
Clint
But to ever reach this speed the cruiser would have to have no mass. And also you will get old less quickly.
Checkerhead wrote:But to ever reach this speed the cruiser would have to have no mass. .
That's where the flux capacitor with a close-coupled bosonic hydro-isolator comes in
Been ticking off a few more small jobs over the last few weeks. Replaced the remaining old brake hoses, all bled up still not 100% though, a little bit of squishy travel before it feels right, need to take it for a drive & test them.
Got a double cardan driveshaft to adapt on for the front. Out of Dan's parts pile, possibly out of an MQ Patrol. Even seems to have good UJ's in it Same size UJ's etc as a Y60 so will bolt on at the diff end. Flange bolt hole spacings are actually the same as full size Landcruiser but the Nissan spigot is much bigger, so went to machine out a Landcruiser flange for the t-case end. Then realised that there'd only be about 1mm of steel left behind the hole So made up an adapter washer instead.
Machined off the weld at the spline end of the new driveshaft & shortened it up, now ready for welding.
Off to borrow Klembo's hoist this weekend & install my low range gears in the transfer case along with a new set of bearings.
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Looking Fine!! Giving me ideas for my 70 series
Had a good weekend of spannering at Performance Mechanical in Taupo. So nice to have the use of a hoist & transmission jack for this part of the job, cheers Klem! Big thanks also to Dan, Jeff & Zac who all helped out at some stage.
Once you've got the transfer case out of the LJ71 you're 90% of the way to having the gearbox out, plus assembling the transfer case has to be done on the gearbox which is hugely easier when it's stood on end, so we took out the whole mess to work on.
Klem had a full Terrain Tamer t-case rebuild kit waiting for me so all the bearings, seal etc were replaced along with the gear install. Installing the new gears isn't rocket surgery but does have to be done with brain engaged. The Marks adapters setup has some improvements like roller bearings on the output gears vs the original bushes, & the new idler gears come on a different shaft & are axially located by taper roller bearings rather than the original, wear prone thrust washers, so assembly is not just the reverse of disassembly. You also need to grind a tiny bit off the inside of the case in a couple of places to clear the bigger gears. But after much consultation of the Mark's instructions & the Toyota service manual it all went back together ok.
A bit of a test drive showed everything was working as it should, low range sure is nice & low, hi range feels about right. The new gears are a bit noisier than std, Mark's do warn of this & recommend a specific lube, which of course wasn't available on a Sunday in Taupo, so hopefully once I get some of that they'll quieten down a bit.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- tomsoffroad
- Flopsie
Did my transfer gear a couple of months ago too. Best money ive spent on my pig
Took the cruiser out for it's 2nd round of testing on the weekend. Did some exploring deep into Tuhoe country with Dan.
Everything is working well. The new gear ratios are really good. No vibes out of the new driveshaft setup. Brakes seem to be bedding in a bit now & feeling more like they should.
Current job is putting in a new set of bushes in the back suspension as a few were due for replacement. Just got the cheap blue polyurethane ones ex trademe, not sure how well they'll last but they should give a bit more stable handling as far as the cert check at least.
Decided to make up some proper size punches for pressing the old bushes out, made what can be a bastard of a job hugely easier, some of em still gave the 20T press a bit of a workout though.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
If you need some genuine rubber ones have a look at
http://www.4wdstuff.co.nz/catalog/toyota-landcruiser-80-series/suspension
Tim
Will see how the poly ones go... at $150 for the full rear kit vs $550+ for the rubber ones I thought it was worth the experiment
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
All new bushes in the back end now. I had a spare set of 80 series rear suspension arms in stock that I put the new bushes in & then I discovered that the existing lower arms were actually quite a bit beefier with bigger diameter tube & forged ends:
The other set I had must be off an earlier model 80 series, not as strong:
With that done the next item on the list was a new tow hitch. The old one was a bit high for the trailer to sit level plus the new tyre carrier couldn't be opened with the trailer on. So first make a bending die then deal to a bit of 16mm bar with the press:
Cut, cut, cut, weld, weld, weld, paint, paint, paint...
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Got out for a bit more testing over new years with some mates. The low gears were very very nice on the steep as farm tracks
All going good apart from a bit of movement in the engine + gearbox mounts at times - the low gears must being torqueing things around. Need some new engine mounts anyway.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
- KIWI_TERRANO
Where you get manual proportional rear valve from?
