40in tahs
40in tahs
quick probe on how much work is involved in puttin 40's on a vitara?
- Beer_Cruiser
Re: 40in tahs
Lots....
Re: 40in tahs
Beer_Cruiser wrote:Lots....
well thats helpful
Re: 40in tahs
i was thinking about suzuki's the other day and found some cool stuff on trademe. After only owning toyotas i looked at a couple of samurai's (sj80 i think?). all coil sprung and solid axles (i didnt know this). Im quite keen to find one of them and just rip the body and bolt a roll cage to it then chuck some ridiculous tyres on it and get the crawler gears in the transfer case and you have a super light, kind of amazing 4x4. so to answer your question, i would say its easy! Just pull the body off.
- skid
- Tyre Man
Re: 40in tahs
reckon if ya gonna put wide diffs under it like 80 series or nissan GU, then the tahs wont be a problem, co they will stick out that far they wont touch a thing
Re: 40in tahs
skid wrote:reckon if ya gonna put wide diffs under it like 80 series or nissan GU, then the tahs wont be a problem, co they will stick out that far they wont touch a thing
yep or I could get some 300mm spacers made up, think the biggest you can buy is 50mm anyone know a goo engineer?
Re: 40in tahs
Stock vitaras are wider than stock hiluxes so they wont stick out that much
Re: 40in tahs
Just use paper clips. As per http://www.offroadexpress.co.nz/Forums/ ... 49&t=8999&
Re: 40in tahs
NJV6 wrote:Just use paper clips. As per http://www.offroadexpress.co.nz/Forums/ ... 49&t=8999&
would do mate but dont wanna add that much weight, would that thin fuse wire suffice?
Re: 40in tahs
Wrong.
Vitara front 1395mm
Hilux front 1420
Vitara rear 1400
Hilux rear 1400
Re: 40in tahs
Wrong.
Vitara front 1395mm
Hilux front 1420
Vitara rear 1400
Hilux rear 1400
close enough
Re: 40in tahs
chevrolux wrote:i was thinking about suzuki's the other day and found some cool stuff on trademe. After only owning toyotas i looked at a couple of samurai's (sj80 i think?). all coil sprung and solid axles (i didnt know this). Im quite keen to find one of them and just rip the body and bolt a roll cage to it then chuck some ridiculous tyres on it and get the crawler gears in the transfer case and you have a super light, kind of amazing 4x4. so to answer your question, i would say its easy! Just pull the body off.
SJ80 were the shitist of them all (mudslut will disaprove ) dont flex - for a coil sprung vehicle and had weaker running gear.
Re: 40in tahs
a build Ive been watching on pirate might give you an insight. Piece of piss if you work for a specialist and handy with the welder - his welds are
http://www.pirate4x4.com/forum/showthread.php?t=851529
Re: 40in tahs
haynzy wrote:quick probe on how much work is involved in puttin 40's on a vitara?
Just cut the guards and your sweet
LR110 ..... LJ50 project
- Landy Rover
Re: 40in tahs
Must have a good chainsaw motor to turn those
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
Re: 40in tahs
lilpigzuk wrote:a build Ive been watching on pirate might give you an insight. Piece of piss if you work for a specialist and handy with the welder - his welds are
That's cool!!!
Re: 40in tahs
Awsome idea!
With a gas axe and a BFH you can make anything fit
Ive seen a vitara at rallywoods with iroks ( photos from when Jafa took his hilux there). If anyone knows it? 40's or only 37's?
There's gotta be some rocks round here SOMEWHERE!
- skid
- Tyre Man
Re: 40in tahs
DMcCready wrote:Ive seen a vitara at rallywoods with iroks ( photos from when Jafa took his hilux there). If anyone knows it? 40's or only 37's?
lol, baby 36s
- mroffroader
Re: 40in tahs
skid wrote:DMcCready wrote:Ive seen a vitara at rallywoods with iroks ( photos from when Jafa took his hilux there). If anyone knows it? 40's or only 37's?
lol, baby 36s
AH HEM they were MASSIVE 36's thank you very much skiddy!
I was running prado diffs front and rear and yea, with alot of guard chopping you could run 40s....
80 series tow bus towing a redneck ass vitara
Re: 40in tahs
SJ80 were the shitist of them all (mudslut will disaprove ) dont flex - for a coil sprung vehicle and had weaker running gear.[/quote]
I will treat that with the ignorance it deserves Rex
Re: 40in tahs
mroffroader wrote:skid wrote:DMcCready wrote:Ive seen a vitara at rallywoods with iroks ( photos from when Jafa took his hilux there). If anyone knows it? 40's or only 37's?
lol, baby 36s
haha jeez they looked massive in the photos. Sweet looking truck though
Re: 40in tahs
DMcCready wrote:mroffroader wrote:skid wrote:
lol, baby 36s
until you saw it up close
