taz01 wrote:finally turbo done and running goes in to dyno next week....
http://www.youtube.com/watch?v=WHOcAyMjZE0
That shit is awesome , well done taz , well done
xj wrote:Taz, any idea where/if a man can hold of some of those bonnet vents in the tron?
Chur
Moriarty wrote:Didja increase the diesel flow to make use of the increased air, or are you just using the "normal" over-fuelling of a Nissan???
coxsy wrote:and sucks more fuel than std too
Chur
Chur
Aza wrote:xj wrote:Taz, any idea where/if a man can hold of some of those bonnet vents in the tron?
Chur
Im sure most sheetmetal companies can make them, my work gets them regularly 300x200 from jackson sheetmetal in chch and they are the cheapest down here i believe
taz01 wrote:some progress....
taz01 wrote:
on another note due to my issues with the fitting i complained to who i bought the manifold from who is offroader off tardme but is also Scarles Performance in auckland....... i at least expected an apology email ph call anything from them i also informed them that my input would be posted on the largest best 4x4 forum in nz (yes i admit i was hoping for freebees to shut me up ) ..... so 3 manifolds sent before one would line up with all the head bolts, then cutting 10/15mm off the bottom front corner to sit flat, small head bolts are needed to make a spanner fit, plus cut away the panel around the shock tower so the waste gate tube doesn't break off from movement of engine, the t3 threaded bolt holes don't align with the turbo these must be drilled out and nut and bolts used and lastly if you have a pto shaft its gonna be tight getting an exhaust to fit
even talking to them they tell me many of these have been sold im wondering how many other people having issues are these cheaper manifolds worth the hassle compared to the dsr ones my opinion 2c worth/bitch/complaint done
TD power wrote:offroader had a stuff up with supliler for manafolds 1st shipment hopefuly 2nd shipment sorted out
Chur
Found some similar vents in the marine parts section at the new FCO store in lower hutt today, they looked reasonably priced as well
007 wrote:Now that is a winch. by the photo it ether has a small drum or big motors. Were do you get these from.
meatc wrote:The tractor link wont last. I used one (or one end at least) in the A arm on my rear diff in my off road only W/C truck. 3 years and maybe 200km later it is sloppy as and the whole back end clunks side to side. They are just not made of strong enoug steel to resist the wear. I though this was going to be road legal too? cant see a certifier liking it either
Users browsing this forum: No registered users and 44 guests
