another terrano/safari project = terrari
The WEHI
Re: another terrano/safari project = terrari
Postby The WEHI » Sun May 04, 2014 11:39 am
derk wrote:good work on the rear barwork mate, not sure where you drive and what sort of terrain but you've got to watch the hilift sticking up so high it makes a big mess of things when you get it hooked up in a tree :x
Been there done that, got the banana jack to prove it
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
passengerpete
Postby passengerpete » Sun May 04, 2014 1:09 pm
:D the old banana jack trick.
yea its way too high :( but it will sit behind the rear seats perfectly. and that where it sits most of the time. but still handy to have options,
trucked
Postby trucked » Sun May 04, 2014 1:34 pm
passengerpete wrote::D the old banana jack trick.
Just an idea but you could swap where the spade sits and put the high lift there, the spade should just come under roof height and fit where the high lift is now
passengerpete
Postby passengerpete » Sun May 04, 2014 6:10 pm
yea that's probably the better way to go about it in hindsight. will rework it next weekend.
The WEHI
Postby The WEHI » Sun May 04, 2014 9:49 pm
forget the jack buggy time pete :mrgreen:
(027 788 1046)
passengerpete
Postby passengerpete » Sun May 04, 2014 10:13 pm
The WEHI wrote:forget the jack buggy time pete :mrgreen:
lol that's top secret. :mrgreen:
passengerpete
Postby passengerpete » Sun Dec 28, 2014 9:13 pm
have been using the truck heaps so the old girl is looking a bit used
use to have tidy paint work... now
[url]Image[/url]
radiator blocked
[url]Image[/url]
radius arms have been bent
sway bar links buggered
[url]Image[/url]
tie rod has a small bend it too.
and stuffed two water to air intercoolers so there going out.
all in all its been worth it had a blast.
but time for a freshen up, and make it stronger and better
passengerpete
Postby passengerpete » Wed Dec 31, 2014 12:46 pm
front mount under way
[url]Image[/url]
on board water is under way, using a marine wash down pump for hosing out radiators and fish ect.
[url]Image[/url]
cant mount tank till I work out where new diff links are going.
roof console almost finished.
who want to give me a sweet deal on a safari 2'' lift springs.
passengerpete
Postby passengerpete » Wed Dec 31, 2014 4:19 pm
extra gauges. water temp, pryo, boost.
[url]Image[/url]
will add oil pressure here. have a speer d/c outlet, and a digital muilt gauge for out side temp, volts. clock
[url]Image[/url]
added a extra din tray to put wallets phones ect
[url]Image[/url]
console mostly done just needs some finishing and upholstery
[url]Image[/url]
has over head storage, two d/c outlets, prs, flip down tablet.
space for extra switches. and a grunt led interior light.
[url]Image[/url]
still needs a sand and some shaping
[url]Image[/url].
passengerpete
Postby passengerpete » Thu Jan 01, 2015 1:27 pm
diff out to make some adjustments
[url]Image[/url]
Checkerhead
Postby Checkerhead » Thu Jan 01, 2015 2:34 pm
Are you on the 4CaB facebook page? I believe Reihana has some secondhand 2" Safari springs for sale. Text me and I will chase it up for you if you want.
Nice work on the mods. Looking forward to seeing that finish roof console.
passengerpete
Postby passengerpete » Thu Jan 01, 2015 6:22 pm
Checkerhead wrote:Are you on the 4CaB facebook page? I believe Reihana has some secondhand 2" Safari springs for sale. Text me and I will chase it up for you if you want.
I had a wee look for the springs, but looks like there sold bugger.
passengerpete
Postby passengerpete » Thu Jan 01, 2015 6:32 pm
dummy fitted axle back was going to link it. but because I want too tow a buggy around, ill leave it stockish and just long arm it, will see how it works or rip it out if it sucks.
[url]Image[/url]
reusing stock terrano lower arms as uppers now and will get new lowers made.
will tac every thing in then get it properly welded by a expert.
poss682
Postby poss682 » Tue Jan 13, 2015 5:32 pm
was looking at this option how far back did it move you diff?
passengerpete
Postby passengerpete » Tue Jan 13, 2015 6:47 pm
poss682 wrote:was looking at this option how far back did it move you diff?
I have moved it about 30mm but also trimming front of rear guards to allow for bigger tyres, lower link extended to body mount behind front doors. top arm 300mm forward so all new body mounts top and bottom.
if you meant how far it would move back on stock mounts then 300mm so touching fule tank. the angles would be different to. hope that helped ?.
passengerpete
Postby passengerpete » Sat Feb 07, 2015 9:53 pm
out with the old cross member in with new. have ditched the terrano rear end, am now using a patrol one. will add extra brackets just encase I decide to go 4 link latter on.
[url]Image[/url]
now the vacuum operated diff lock on the patrol/safari what's involved in getting them working is it just a case hocking it up to a vacuum and somehow switch it or do ya need the hole lot off a wrecked one with the solenoids ect.
Crash bandicoot
Postby Crash bandicoot » Sun Feb 08, 2015 1:00 pm
You should be able to use the vacum actuators for the EGR system(if you kept them) wire one up with a switch on the dash
passengerpete
Postby passengerpete » Wed Apr 29, 2015 1:56 pm
suspension re done, bigger tyres fitted
[url]Image[/url]
gary_in_nz
Postby gary_in_nz » Sat Jun 27, 2015 11:18 am
wow the terano looks mean!!
passengerpete
Postby passengerpete » Sun Jun 28, 2015 9:32 am
gary_in_nz wrote:wow the terano looks mean!!
cheers mate, its getting harder to pass as standard now lol.
drive it ...
Postby drive it ... » Mon Jun 29, 2015 7:58 pm
Hmm - maybe you should have just chucked the 'rano body on a Saf chassis back on page 1. Nah, wouldn't have given us popcorn scoffers as much entertainment. Wicked build, love your engineering / fab work.
passengerpete
Postby passengerpete » Fri Jul 17, 2015 10:58 pm
drive it ... wrote:Hmm - maybe you should have just chucked the 'rano body on a Saf chassis back on page 1. Nah, wouldn't have given us popcorn scoffers as much entertainment. Wicked build, love your engineering / fab work.
haha cheers, yea that would have been the smart move, luckily im not that smart. enjoy ya popcorn :D
well im here ill I've been messing around with some storage. as putting wet muddy recovery gear on top of camping gear was not ideal.
started by stripping out the back of truck.
[url]Image[/url]
starting making some drawers
[url]Image[/url]
brought some 80kg drawer runners. and ended up shorting drawers by 60mm so I could add some 6x9 speakers to front of box.
[url]Image[/url]
[url]Image[/url]
brought some marine carpet and had a go a aphousting
[url][/Imageurl]
left rear pocket has a small deep cycle battery. mostly done but would like to make a cargo barrier but cant rush these things.
[url][/Imageurl]
tomsoffroad
Flopsie
Postby tomsoffroad » Sat Jul 18, 2015 7:13 am
Tidy bro. Nice work :D
Mattman
Postby Mattman » Sat Jul 18, 2015 12:24 pm
Very nice. Cargo barrier will allow you to pack the rear to the ceiling. Helps recover the space lost from the drawers.
Checkerhead
Postby Checkerhead » Sun Sep 13, 2015 9:02 am
Just had a re-read from start to finish. Nice work! Looks like a very complete west coast type truck. Keen as to get out on some tracks with you! (hopefully sooner than the few years it will take to get mine going).
jarmore
Newbie
Newbie
Postby jarmore » Fri Oct 09, 2015 1:48 am
Hey mate,
literally created an account to say just how incredible the whole read through of your build was from start to finish. Such a motivation. The reason why I write to you is I'm looking at getting a fourby at the moment, and have always had a thing for WD21's.
My question is, firstly, with the SAS, is the front axle like mega wide compared to the rear? Just looked odd.
Secondly, have you ever tried to get a mattress in the back, this is a big deciding factor for me so I'm really hoping one will fit.
And lastly, have you ever had a hunger for more power, what sort of engines can you fit in these trucks? I really hope you can talk me into a WD21, haha. The small engine really does worry me though, has to be a diesel and I'm unsure if you can fit a TD42 or anything of the likes.
BlakeNZ
Postby BlakeNZ » Fri Oct 09, 2015 4:25 am
the QD32 pretty much bolts in where there TD27 does. A few minor things need changing, documented a couple of days ago on this very forum. It gives a lot more torque.
passengerpete
Postby passengerpete » Fri Oct 09, 2015 9:01 pm
jarmore wrote:Hey mate,
there a cheep wee wagon bit light in the front end heres some motivation
[url]Image[/url]
I use offset wheels staged i'll drag up some old pics so ya can make ya own mind up.
[url]Image[/url]
[url]Image[/url]
before the drawers I slept in it all the time. on trips I'm 5'10 ish slight knee bend remove back seat ya will be fine.
yea a terrano may not tilt earth off its axis if ya dump the cluch but luckily there is allways a nutter with a a spanner and a welder somewhere.
I guess as blake said the qd32 is a easy swop, or if ya have deeper pockets or sleeping bags attached to ya shorts ive seen a rb20det in a d21 navara same thing sort of thing so ya could squeeze in a rb26 build it up abit 800hp or more. a better fit would be a vh41 Nissan v8 or vh45 or 4bt Cummins, the qd32 is getting expensive for what it is so I guess the sensible option would be a supercharged vh45 quad cam v8. anything's possible
BlakeNZ
Postby BlakeNZ » Fri Oct 09, 2015 9:13 pm
QUOTE "the sensible option would be a supercharged vh45 quad cam v8" YEP-THIS!!!! it's only logical. :) Man that made me laugh out loud- a pearler, Pete.
lax2wlg
Postby lax2wlg » Sat Oct 10, 2015 1:32 am
Looks f@@@n cool Pete.
What does she weigh in at now with the Safari gearbox and front axle and bars/winch etc? A touch under 3 tonnes?
Users browsing this forum: No registered users and 4 guests
