John's surf project v8 and SAS
jonossiksilvia
Post by jonossiksilvia »
hi all
so a few years ago i had a 1990 v6 surf and due to some issues i had to sell it. but ever since i sold it i've wanted to build 1 from scratch - my ideal surf :twisted:
so here it goes:
brought the truck standard early feb 2011
so after already owning 1 in the past i knew what i wanted to do to it
time to start only a week after buying it sent it to the shop
rip this stuff out
and throw this in
half way through
and this is the result which included lifting the rear to match, some manual converted prado fwh
next was fitting a 40mm body lift
to fit 4 of these including a spare 35/12.5/15 creepy crawers on 15x8 rims
result
Last edited by jonossiksilvia on Sun Nov 25, 2012 12:30 pm, edited 9 times in total.
jonossiksilvia
Re: John's surf project
next was to get ride of this peice of crap
so 2 weeks after getting the truck back from the workshop this happened
which resulted in this
and this is whats going in
so some time was spent getting everything ready to fit the engine:
replace cambelt, waterpump, idlers, tensioner, rotors
replace starter motor as old 1 was unable to be rebuilt due to seized bearing with brand new one
new accessory belt and bearings for idler and tensior
gut internals of hydro fan unit
rebuilt powersteer pump as was leaking
remove tail housing on 1uz auto and fit transfer case on
mounted handbrake on inside of firewall
cut off old engine mounts off of chassis
remove other parts from engine bay that were not needed
jonossiksilvia
heres the transfer case mounted to the auto
getting ready to drop into the hole
getting close
time to make some engine mounts. rubber mounts are brand new from the mountshop and are for small diggers $120nzd for 2. note only tacked at this stage - will get finished shots
and here is transfer mount we made up to fit to oe gearbox cross member note also tacked and will up date
results:
how the factory shoulda made surfs:
RJT
Post by RJT »
Very 8)
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
rokhound
Post by rokhound »
Good stuff Jono.
jonossiksilvia
finished engine and transfer mounts
got exhaust done twin 2.5inch systems. finish at rear diff for now till i do rear bumper then will extend
fitted the required driveshaft hoop for cert
oil filter setup and a tee to use factory pressure gauge and also oil pressure warning light
here is the cooling setup. powersteer cooler left, radiator middle and trans cooler right with own 7inch fan behind it
and the fan controller
the diesel cluster with a 2.0l 4 cylinder petrol tach fitted
handbrake fitted on inside
centre console fitting and hooked up. needed no mods
heres a picture of the electric hubs that i got converted to manual. these are more reliable than the electrics. they also better than changing to normal manual hubs as they require a spacer to be made up which always snap hub studs
so guys its all up to date of where im up to on the truck
jonossiksilvia
RJT wrote:Very 8)
jonossiksilvia
rokhound wrote:Good stuff Jono.
cheers mate. your truck looks tank :twisted:
suzukisport
Post by suzukisport »
Awesome work, truck looks great 8)
KIWI_TERRANO
Post by KIWI_TERRANO »
what happened to the old motor ?
looks awesome mate, makes me miss my old surf
jonossiksilvia
suzukisport wrote:Awesome work, truck looks great 8)
cheers mate
jonossiksilvia
KIWI_TERRANO wrote:what happened to the old motor ?
old motor got sold off
i bet it does. got axle swap done by same guy as you
jonossiksilvia
so the list of things to do has gotten smaller
fit the high speed winch - engineer mate making up mounting plate to mount it then can build rest of bumper off of it.
fit the aftermarket 4.88 r&p gears and locker for back
make up running boards
fit mates old rear bar setup
finish the last part of wiring motor already runs :twisted:
make up snorkel
and go for cert
mud_slinger
Post by mud_slinger »
nice work jono. looks real good. who did the fab work?
when is the test drive taking place?
needs more curry
0272593533
jonossiksilvia
mud_slinger wrote:nice work jono. looks real good. who did the fab work?
cheers mate. me and my engineering mate done all the work except the sas. usual story of me tacking everything and mate doing finale welds.
already been for balt up street. smokes the 35"s to much without the locker :lol:
off road test drive will be once got cert as my s14 turbo dont have a tow bar to trailer it anywhere :lol:
mud_slinger
let me know when you doing the off road test, mu isnt far away from going for a run too
needs more curry
0272593533
niblik
Post by niblik »
sweet chap! looks goodly and you'll love the power i bet! heh..
make sure ya post up when ya havin a shakedown run..
jonossiksilvia
mud_slinger wrote:let me know when you doing the off road test, mu isnt far away from going for a run too
will do mate.
jonossiksilvia
niblik wrote:sweet chap! looks goodly and you'll love the power i bet! heh..
cheers. will post up when it will have test run. only be day trip so not to far from home if turns to crap. prob be a waimak or ashley run
pruggerdore
Post by pruggerdore »
I dont really like sufs but you seem to have fixed that one. well done
jonossiksilvia
pruggerdore wrote:I dont really like sufs but you seem to have fixed that one. well done
cheers. i wanted a 4 door wagon that wasnt to big. another option was looking at was a prado but they little bit bigger so went for surf.
Drurban
Post by Drurban »
That is a nice looking 4WD, you make it look so easy to do :lol: , nice work.
Chur
jonossiksilvia
Drurban wrote:That is a nice looking 4WD, you make it look so easy to do :lol: , nice work.
Chur
cheers mate. will look a bit different once bar work is done. if i wasnt making it to do hard 4wdriving i would of kept the factory bumpers and running boards cos it looked clean
T-Boon
Post by T-Boon »
Dream surf right here..
Looking damn good !
To Boon or not to Boon.
hosehustler
Post by hosehustler »
great work, awesome little write up, you may have to do some rear guard chopping even with the 40mm lift, when it sarts flexing offroad may hit ya tyres, I bet that V8 sounds the part, you'll grin everytime ya start it up :mrgreen:
I hate signatures
jonossiksilvia
T-Boon wrote:Dream surf right here..
Looking damn good !
Cheers mate
jonossiksilvia
hosehustler wrote:great work, awesome little write up, you may have to do some rear guard chopping even with the 40mm lift, when it sarts flexing offroad may hit ya tyres, I bet that V8 sounds the part, you'll grin everytime ya start it up :mrgreen:
Cheers mate. Yeah was thinking bout guards but time will tell. I love that sound of it. Can't wait to hear it going full tit suck in some mud. Been having a good read up of ur surf buildup - its how I want mine to sorta look.
dave_ln130
Post by dave_ln130 »
flick me a text when you head out ,ill find a hole you can pull me oput of to test it hahaha chur
i got a tow bar and transporter.........
jonossiksilvia
dave_ln130 wrote:flick me a text when you head out ,ill find a hole you can pull me oput of to test it hahaha chur
good man dave
jonossiksilvia
well the diffs have been sent in to rick at 4wd acc to get the ratios changed and a locker fitted. mate dropped of the winch mount he made me so i can start doing some bar work now
