Volvo C304 4x4 Build/Restoration - WR002
geckoadventure
Re: Volvo C304 4x4 Build/Restoration
Postby geckoadventure » Fri Nov 02, 2018 10:50 am
wjw wrote:I think I need one of those for the wife for the school run :-D
Tnat would be awesome imagine 15 kids jumping out at school in little allblack shirts then doing a haka and running into school lol.
Last edited by geckoadventure on Fri Feb 01, 2019 12:30 pm, edited 1 time in total.
Cameron
Postby Cameron » Fri Nov 02, 2018 9:45 pm
Awesome mate must feel good to get it home
geckoadventure
Postby geckoadventure » Sun Nov 11, 2018 10:54 pm
10 November 2018
Trying to work on the Volvo at the workshop. We finally got a cleaup run at the raditor testing and flushing last weekend. 1 hour idling away watching the temp run up and down and the fan cutting in etc. Did about 5k in High Range and then low range then it got permanently stuck in LOW) and tested the radiator at high revs low speed etc. All worked fine. Now have to pull the leaking waterpump sigh. Installed the second window wiper arm so finally it has 2 complete window wipers next is window washers. Tested the wipers in the usual afternoon rain.
The front wheels shaking with the power steering is still not solved. We have aligned some parts better and then discovered water in the fluid. We are now removing the power steering hoses etc to flush it all out and try again. This and a return brake pedal spring are needed then it can go for inspection.
Hunting down parts is totally frustrating in KL's horrific traffic everything is so far apart lost 4 hours yesterday chasing parts all over town. Left the 24 bolts for the rear seats sitting in the bolt shop and it was too late to go back when I realised. Still trying to find a upholstery shop (Kussen shop here) locally to get the gearlever cover made and get them to come and try and cover the tunnel.
Still have the lack of power issue to sort out the turbo cuts in then you can feel the power drop away. A boost gauge needs to be fitted to see what happens.
The gecko footprints are to be continued down and along onto the battery box and along the fuel tank with 2 new panels to be cut and bent up in the coming weeks. I have a air intake shroud to make also to force air into the radiator.
Progress is slow and frustrating.
When I compare Volvo 1 and VOlvo 4 one realises how far Volvo 1 has progressed.
It looks good just needs a coat of paint.
We went for coffee and went in the UBER Pinz. Very nice very smooth very noisy lol just like a Volvo.
The previous harness seat belts plastic covers broke in our humidity and so bought a new set but the thread on the eye bolts down not match damn IMPERIAL vs METRIC. ANother visit to the bolt shop is needed.
Finally 2 wipers are on the Volvo. Window washers to go.
After going home early due to a very unhappy stomach the big 8kg cat decides to sit on my chest and asks how was my day. Crappy I say.
geckoadventure
Re: Volvo C304 4x4 Build/Restoration - WR002
Postby geckoadventure » Wed Nov 21, 2018 11:54 am
20 November 2018
Public holiday.
Progress is slow and frustrating. Losing so muuch time trying to obtain door rubber seals so far 2 saturday morning. Finally have some clues as to where to get door seals for older vheicles in Kuala Lumpur. Even the bolt shop is 20 minutes away on a good day. Still yet to find a Cushion shop to do work for me.
The power steering is still an issue and a whole saturday was lost trying various remediations to stop it shaking. We have now drained the power steering fluid out aws it appeared to have awater in it and refilling and removed the power steering hoses and replacing with new ones.
Went to buy 2 more seats for the rear only to get way out to the shop I use to discover it closed 2 months before. Now have to find another seat shop which sells seats.
There is only 2 items to fix before we can get the inspection done:
Power steering shaking
Brake pedal return spring - done fitted
Rear cabin seats 2 to buy and get all bolted down.
Spring for the brake return fitted.
Seats and frames being bolted in and the spare parts etc being removed from the rear cabin.
Now I'm away on and off for 3 weeks on holiday first 4 days are doing delivery of 30 Orang Asli kids back to their remote jungle villages from the orphanage schools they board at in Kuala Lumpur. We have already lost 1 4x4 yesterday due to a rollover during a foodrun in the terrible terrain.
THen I'm off fishing by myself on the boat for days and then river fishing in Thailand with an armed ranger per pair off fisherman.
I have also gone and bought a 80 Series Landcruiser and will be selling the mighty little Isuzu after it gets some much needed TLC.
DieselBoy
Postby DieselBoy » Thu Nov 22, 2018 8:30 pm
Be scary in the back there with out any windows!!!!
Your power issue:
Fuel filter replace (look for diesel bug from being parked)
Turbo waste gate - check its not stuck open/seized from sitting (take the little hose of and jam the air duster up it to make it actuate)
Sounds to me like the injector pump is not supplying enough fuel to support the boost, of the waste gate is half open, and its bypassing and not driving the turbine properly
Cameron
Postby Cameron » Sun Nov 25, 2018 2:15 pm
check boost aneroid operation also!
geckoadventure
Postby geckoadventure » Mon Dec 31, 2018 10:25 pm
29 December 2018
After a frustrating period of off road charity work and broken annual leave getting called back to the office twice when less than 100k from the lake with your boat on the back is no fun).
A jungle fishing trip in THailand which resulted in a trip to the hospital for 5 days
Tossing the timing belt on my new 80 Series Landcruiser hence causing massive damage and many other incidents its been a frustrating non-holiday.
Volvo work has slowed till they sort out the pesky PINZ which is still causing huge manpower issues 3 times the transfer case has been removed and replaced and now it needs to come out again as they cannot find the errant bearing - ME I think it's a bearing in the rear DIFF in the PINZ SPINE.
So back to the Volvo we have stripped the power steering off the Volvo so we can do the inspection, Saturday morning was spent getting the remaining seats for the Volvo. The distances in KL aare causing huge logistics issues rounding up components. THen off to the local hydraulic shop to get hose made to go from power steering pump back into resivoir. He saw me coming and charged me more than double the IPOH costs for a hydraulic hose.
Calculations for the power steering pump and the steering column unit and the hydarulic ram are also being done to see where the issue is. I have already found the washers on the banjo bolt are .6mm too thick resulting in lost throughput on the hose.
Seat belts were fitted. Remaining 2 steats fitted then I realised I had bought 4 narrow and 4 wide seats and the wide ones are also taller - oops.
A test run still has the gear change issues - we think the bend put in the linklage is causing some issues - further investigation is required.
Also the issue of HI/LO from the same gear lever (R/1/2/3/4/HI/LO on the gear lever) and leaving the truck in LO is still being investigated we think the BENT linkage is the issue. I'm looking at a electric servo arm to go HI/NEUTRAL/LO and eliminate the gear lever change. We are also going to explore CABLE linkage change and dispense with the linkage arm.
I also need to find out why it looses a small amount of coolant from the radiator each week.
We have the HORN and Brake issue to fix then it can now go for inspection.
Then it was time for the Volvo to earn it's keep as a stepladder.
Seatbelt connection.
Image seatbelts
Rear seats all fitted but now I need to do some moving and matching.
Image seats
The cabin is a mess while I wait for the now late gear lever cover.
A short video of the VOlvo moving back into its kennel.
Last edited by geckoadventure on Fri Feb 01, 2019 11:14 am, edited 3 times in total.
Cameron
Postby Cameron » Wed Jan 02, 2019 5:59 pm
Awesome to see it moving under its own steam!
Smurf
Postby Smurf » Fri Jan 04, 2019 7:25 pm
geckoadventure
Postby geckoadventure » Fri Feb 01, 2019 11:50 am
1 February 2019
We have been beavering away on the Volvo as much as one can in a open air workshop when it's 34 celcius. I have all the rear seats now bolted down properly and the final 2 different seat bases adjusted to fit.
The carpet for the cabin floor has been done with the passenger seat floor complete. The driver side needs a mistake corrected but will be installed on 1st Feb 2019.
The brakes have been an issue and finally after rebleeding the brakes awith my trusty new assistant which necessitated the removal of each wheel to reach the bleed nipple sigh. Then the retest and still we had no brakes.
Last weekend we took all the wheels off and ran the Volvo on jacks,, that was scary. Hmmmmmmmmmmm problem found. The vaccum was not working it's shared with the PTO and the 4x4 via 3 T-joints so we direct connected it to the brakes and we had brakes. But it still will not lock the wheels up so further attention is being paid this coming weekend.
We looked at the HOrn and tried to connect the wiring to the steering wheel with no success. A separate dash switch is being setup this weekend.
Once these 2 items are completed we can attempt the dreaded re-registration inspection.
Today is a public holiday so I'm working on the templates for the rest of the carpeting in the transmission tunnel and footwells etc.
Giving the new sidekick the wheel nuts to undo. At 44kg the tire is heavier than her lol.
Last row of seats bolted dpown properly.
Working on the carpet templates to take to the cushion shop.
Zing clinging to me in a 2 hour thunderstorm he hates thunder.
Preparing the floor for the velcro to be glued down
The front row of seats almost ready for the last seat to be bolted in until I cut the wrong lugs off and had to reweld them in lol. Felt such an idiot.
The passenger seat with the floor carpet fitted
Just to prove the lights work.
Today's goal is to get the tacho working via the page instruction guide and the carpet templates to the cushion shop.
wjw
Postby wjw » Fri Feb 01, 2019 2:18 pm
:D Still reading...
Who knew Prados could fly?
Cameron
Postby Cameron » Fri Feb 01, 2019 7:15 pm
Getting closer mate this is great
nivaman
Postby nivaman » Sat Feb 02, 2019 10:44 am
Looking good.
geckoadventure
Postby geckoadventure » Tue Feb 05, 2019 2:23 pm
3 February 2019
Well 2 more days on the Volvo has brought success and total frustration. Weve had FRI/SAT/SUN this week on it.
So to start off on a healthy manner I had breakfast a waffle and ice cream at our health shop near the workshop lol.
My electrics whiz buddy turns up and we install the HORN button. Wahoo only BRAKES left for the inspection.
Then we try and get the TACHO connected. Cannot reach the tach wire from the fuel pump - oh crap. Go to use the "P" of the alternator only to find its a PETROL alternator and no PINS are available. Order a TOYOTA DIESEL Alternator from a friendly mechanic - delivery after 11 Feb. Then onto the SPEEDO. The halls effect unit is already installed on the driveshaft. However we find one of the l;ocking nuts has vibrated out. More issues to solve cannot get a nut bolt shops are all closed until the 11th.
A rebleed of the brakes made no difference so we elected to just pump a lot of fluid out of the brake lines, OOps suddenly black fluid came out oops so we decded off come the front callipers for a full rebuild even though the brakes were contracted out to be rebuilt a few months ago.
The end result was some very sick looking callipers with 6 of the 8 pistons not moving and all the holes blocked up.
Meantime Andrew had completely stripped the Pesky Pinzgauer rear tandem axles completely apart to find the mystery whine only to find a single diff bearing gone!. It's CNY he also cannot get any parts until the 11 Feb.
Meantime the second calliper is in the 12v battery charger and baking soda cleaner and enormous amounts of crap come out.
The callipers are installed after we get the rebuild kit and special order of isuzu truck window washer nozzles are obtained after they close for the CNY celebrations until the 11th February and reassemble the callipers.
Meantime I have most of the carpet templates cutout mainly because the Volvo will not fit under the Kussen/Cussen/Cushion/Upholstery workshop everythng has to be done remotely. Only a few remain for my assistant to help with tomorrow.
A last minute brake test run of the VOlvo is a failure it takes 2.5 street lights to stop over the normal 1 and a bit and then the engine starts dying - no fuel. We realise the electric pretank pump is no longer clicking but its working slowly. Strip it out and find its 24volts. Damn they forgot to change n the 12v conversion it's browned out.
Sunday
My trusty assistant turns up so she gets the carpet templates to complete. We have to finish Volvo 1 before we can recomence work on Volvo 2 and Volvo 3 (is going to be started side by sde also).
She is kinda tiny and flexible and works unconventially lol.
However, by 6pm she has all but one carpet template completed ready to see if the cushion shop might be open Saturday since they are not chinese owned lol.
While she did that I got the window washers roughly connected and tested successfully in several test positions as we are trying to avoid drilling holes in the cabin.
The end of a frustrating 3 days.
Tuesday and Wednesday is CNY. So I will be back on the Volvo on Wednesday, wife has told me to keep working on it to get it finished.
Petemcc
Postby Petemcc » Thu Feb 07, 2019 6:03 am
are you getting a hard brake pedal? After a long project build I spent ages chasing a brake issue only to find I had my rear calipers on the wrong side which moved the bleed nipple to the bottom and wouldn't get the air out of the caliper. Worth a look. Check all you nipples are high!
geckoadventure
Postby geckoadventure » Thu Feb 07, 2019 11:43 am
Petemcc wrote:are you getting a hard brake pedal? After a long project build I spent ages chasing a brake issue only to find I had my rear calipers on the wrong side which moved the bleed nipple to the bottom and wouldn't get the air out of the caliper. Worth a look. Check all you nipples are high!
I am getting not enough pressure no matter how hard we pump or press. The callipers are correctly installed.
The callipers used to work the DISCS were the first item changed and then driven for over a year before we started the restore process. The only item different is the new master cylinder which we now think has gone off in the heat and humidity here. All the brake lines were also replaced.
1bad4x
Postby 1bad4x » Thu Feb 07, 2019 4:56 pm
Have you gone up a size or 2 in hose diameter/length...? May make minor/enough of difference, more fluid more compression so the master cyl may not move enough quantity.... Just a thought
Petemcc
Postby Petemcc » Thu Feb 07, 2019 8:20 pm
Hose diameter and length will not effect volume of fluid that is needed to be moved. only the caliper pot size and stroke will as its a closed system.
How does your pedal feel? Firm or spongy?
Brake booster in good condition/got vacuum?
geckoadventure
Postby geckoadventure » Fri Feb 08, 2019 1:58 am
Brakes are soft to push then get harder - pumping makes no difference to them they are getting worse we had more brakes when we had no vaccum, We think the brake booster has gone so its coming out friday night and saturday.
geckoadventure
Postby geckoadventure » Sun May 05, 2019 3:59 pm
7 April 2019
Got my little sidekick to help out but since he is recovering from his motorbike accident he slept all arvo instead
Then the arvo thunderstorm rains started and we all headed for the treehouse and talked shit for 3 hours and drank tea.
Pulled the window washer and checked for leaks.
The carpet is slowly being installed.
Drivers side is a mess while we fix up the brakes issue
Slowly the carpet is installed.
Rubber Door seals installed.
geckoadventure
Postby geckoadventure » Sun May 05, 2019 4:00 pm
28 April 2019
Made an Anderson plug jumper lead to made jump starting very easy and cried over the state of the batteries today's plan to start the truck again was shattered.
Last edited by geckoadventure on Sun May 05, 2019 4:19 pm, edited 1 time in total.
geckoadventure
1 May 2019
There's not been a lot of real activity on the Volvo 6 weeks of weddings, birthdays a sick friend the passing of my 15 year Rawang Toyota Professor Mechanic. Collected the Landcruiser finally from IPOH 200k away then more issues with the Landcruiser breaking down several times since causing the loss of 2 Saturdays. Then the breakdown of the RED jungle truck and trailering it 70k from town since I no longer have my Toyota professor he did however before he passed recommend a new mechanic 70k from town.
Now back to the Volvo's
We have progressed in the brakes issue to purchasing a 80 Series Landcruiser twin diaphram booster and master cylinder and now im waiting for Andrew to mount it remotely. However the pesky PINZ still torments us and only on the 1st did they get the pesky PINZ back together with all new bearings in the transfer case and the rear differentials and wheel bearings etc then upon testing late on 1st it was still making a whining noise leaving work on the Volvo's stopped.
The window washer was removed as we thought it was leaking it's not now we are finding a new location for it as the 80 series booster is going in that location.
I have made a bracket for the radiator overflow and mounted the overflow bottle.
We have worked on fitting the doors correctly and straitening a hinge out has sorted out the passenger door bottom. The top is having screw issues preventing the door being bolted down flush.
All the front door seals have been fitted and removed.
We lost the 3 batteries when they suddenly dropped to 2 volts overnight. They are now in a battery revival shop.
geckoadventure
Postby geckoadventure » Fri Nov 22, 2019 10:44 am
A terrible update
We had the haze no work was done on the Volvo I/2 or 3 just stayed indoors for 4 weeks as the workshop is a open workshop the haze made eyes water etc so I stayed away.
We have rebuilt the brake pedal it's almost finished and we have found the brake issue we had 1cm of master cylinder travel not 3.5cm like we need to apply sufficient pressure.
Volvo 1 has spat its batteries sigh 1 deep cycle battery needs to be replaced as will the other 2.
I have been in hospital due to the haze and ended up with serious bronchitis sigh
I hope to have the brakes in by XMAS as we are off this weekend for days to deliver 200 more kids to the jungle villages sfter the end of the school year. Mission impossible monsoon rain and 12tonnes of food to deliver up to 60k into the jungle. From last weekends guys attempt it's 1 day each way or more. I have 12 hardcore trucks with me to try and achieve this. I am on 3 weeks holiday after this so no updates or work till 21st December. I will do a story on the CSR trip when I get back.
Volvo 2 has no progress apart form the new rear window being made up.
Volvo 3 no progress but I am about to pull the cabin off and get it blasted.
Mr Brown the "guard" dog from the workshop who was my weekend companion for 3 years in IPOH is no more he was badly hurt and passed away in a jungle accident recently leaving everyone upset
I hope to have good news by XMAS..
Cameron
Postby Cameron » Fri Nov 22, 2019 6:00 pm
Bugger! Still watch the threads mate can’t wait to see her finished keep plodding along!
geckoadventure
Postby geckoadventure » Thu Dec 05, 2019 1:31 pm
I'm back 70 kids delivered and 11 tonnes delivered of food in what turned out to be an epic 3 days 4x4 trip and a new gang of dediciated volunteers and they are recruiting more volunteers. The Hutan Skool bus tribe has been formed "Jungle School Bus Tribe".
I'm now taking a "holiday" working on the Volvo this week
Today I only have some nylon spacers to install to the clutch master cylinder bolt and we will connect the batteries prime the fuel pump and try and start it then take it for a test run.
The revised brake master cylinder and pedal assembly is refitted and the brakes finally have feeling and seem to be working properly with the engine off.
The river which occurred when I filled the radiator has been fixed with 2 broken hose clamps being found and a split hose. Took me a day to fix them all up.
If it all goes well I will post a video up tonight.
geckoadventure
Postby geckoadventure » Wed Jul 15, 2020 10:33 am
21 October 2019
We have changed the fulcrum point of the brake pedal and given it enough travel to push the piston 3.5cm and moved it around a little. It has been fitted and the brakes bleed after a nightmare with the fuel tank and the batteries.
1. The truck would not start so I bleed the fuel line but it would not bleed so I made a separate fuel pump primer still it did not prime. Some diagnosis resulted in me taking the fuel tank apart and after a fuel pump which got so hot we could not touch it we realised we had a blockage, cry some diesel sealant blobbed up and blocked the tank sob. Found it at the elbow joint.
2. Bypassing the existing fuel pump and and piping got the truck up and running after 2 days of trying to figure out why the dash lights would not work.
3. We bleed the brakes and now the truck engine stalls when you step on the brakes. We still are waiting for the tank to be reinstalled before we can do a proper road test.
4. Then we have pulled the tank out and inspected everything. All steel parts inside the tank removed as some of them were rusting and we have replaced it all with ALLOY parts and welded in any fittings and no more sealant except on the fuel gauge.
5. The filler cap/nozzzle is away being turned from high quality alloy tube and made into 2 parts to allow the tank to be removed etc.
6. The window washer tank was removed and cut and trimmed so we did not have to remove the gear lever to remove the window washer tank in future.
7. Found and fixed the radiator leak. Cheap hose clamps are never good. 3 clips took me the best part of the day to change lol.
Last edited by geckoadventure on Thu Jul 16, 2020 1:47 am, edited 3 times in total.
geckoadventure
Postby geckoadventure » Thu Jul 16, 2020 1:34 am
9 December 2019
Well its been a long time since I updated and many weekends of work on the Volvo lost
Kids charity kayaking trip has been and gone
More funerals and weddings taking up weekends etc.
The Indonesia fire haze has been and gone we lost 4 weekends of working on the Volvo due to the poor quality air.
It took a long time to fix the brakes and we have also been letting Hotpants our wanna learn as much as I can chick loose on stuff so I have spent time supervising her.
As if I didn't need more shit in my life I bought a Landcruiser 80 cheap so I could take the 1HDT turbo diesel engine out and use it in the new big jetboat we are building next year. However, we looked at it and decided we could fix it up and make it driveable. So new steering bushes a complete rear axle and a brakes rebuild it ran. not bad for 580,000 kilometers on it. It's new name is Elcheapo. I picked up a spare modified WARN 8274 I had lying in my lounge (yes) and fitted it to the 80. Wife was happy lounge was cleaner. It will need a engine rebuilt in the future. Then we decided hotpants could have it for her upcoming charity work so she could get sponsors. Now we need to do the interior and put a manual gearbox in it. Now we need another 1HDT for the boat lol.
We did the end of school year return the OA kids to their remote villages and a new charity 4x4 group group is born "Hutan Skool Bus" or "Jungle School Bus". More
charity work is now wanted by the new crew.
The video is coming still of the overnite 15 hours drive in and 13 hours out. I will do a separate article on this later.
The tank is out waiting for the new custom neck filler to be built.
geckoadventure
Postby geckoadventure » Thu Jul 16, 2020 1:49 am
28 December 2019
The new custom filler neck is being prepared to be fitted.
and being welded down.
geckoadventure
29 December 2019
Tank fitted back and primed ready to test fire.
geckoadventure
Postby geckoadventure » Thu Jul 16, 2020 1:50 am
4 January 2020
Haha now a air line let go to the compressor had to track down the horrendous noise to find the broken hose line lol.
Playing with the speedo sensor setting it up so we could test it without running the truck on the road.
Finally success we got it to work and the start sequence working correctly.
A GPS sender has been ordered and a tacho sender and a boost gauge and a EGT. All due to arrive from USA on 1 Feb.
Even worse new the mighty 80 Series I purchased has failed an inspection I need to cut it up and do what I can to salvage it to a new vehicle.
Users browsing this forum: No registered users and 44 guests
