churchill wrote:MUDFINDER wrote:churchill wrote:You might need an expansion joint in the exhaust cross over pipe between the two banks, when the pipe heats up it expands and might force the two manifolds apart causing the blown gasket...
I can completely understand where you're coming from there! Just picking brains at the moment, but would it not be the same as the factory one then? Cause that doesn't have a flexy either?
Check this out, if this is the right manifold there is an expansion joint in the middle. scroll a little way down the page:
http://krasnoyarsk.baza.drom.ru/nissan-vg30det-kolektor-i-forsunki-12045535.html
according to calcs with a 600mm long pipe at 700 degrees the pipe lengthens by 5mm over room temp length.
Oh Yeah, i see what you mean.. I may cut a section out of the front of mine in that case & put one in place! I'm sure it will help anyways, even though everything was fabed up correctly
