zukmeista wrote:Karmas a bitch ain't it...
Didn't ask for your opinion
passengerpete wrote:td42 is a long motor and heavy, especially in a terrano. a vh45de might fit better still lots of cutting out inner guards still
J_Dub wrote:zukmeista wrote:Karmas a bitch ain't it...
And that's why u go wheeling all by yourself and rely on others to pull you out.... Cause ur a dick with no mates
passengerpete wrote:if the to hard basket is chocker, then perhaps replace the bent conrod in ya truck, take an hour and see whats locked up in ya motor first it may not cost to much to get yours going again even a s/hand motor might be to go. a engine conversion is a bit extreme lol.
datsunsafari wrote:The bombing range is a no go area bud you might want to think twice before going up there and then posting it up online.I know a couple of chaps that did the same thing,they got a trespass notice that included the woodhill 4wd park
MUDFINDER wrote:Does anybody know if,
1: My factory manual vg30 gearbox will bolt up to a newer QD32 Turbo EFI engine? http://www.trademe.co.nz/motors/car-par ... 739391.htm
2: If sub-frame/cross-members and engines mounts are similar/same?
I know that the diff ratios are different in the diesels compared to the petrol terrano/pathfinders and a QD32 is looking like a hell of a alot easier of a conversion than a 6 cylinder diesel engine
J_Dub wrote:^^^ I was thinking the same, the big brother motor from what you have now...
But maybe seriously consider the td27?
Power and economy and simplicity.
The VG motors are a prick to work on aren't they??
MUDFINDER wrote:I didn't even think about it but a VH45 V8 Quad cam would be sooooo dope! i found one that's on $1 reserve on trademe http://www.trademe.co.nz/motors/car-par ... 720811.htm May have to place a bid....
lax2wlg wrote:Howd you get on Mudfinder?
Did you find another VG30 to slot in?
jonossiksilvia wrote:alot of nissan ecus can have chips fitted and then tuned. talk to a local dyno tuner near you and they should be able to help you. alot of silvia and skyline guys get it done and can suit high horsepower - will be alot cheaper than an new ecu.
jonossiksilvia wrote:check out this page but only thing is chch. someone in auckland should be able to do it. http://www.nzefi.com/dyno-tuning/
Users browsing this forum: No registered users and 18 guests
