paj1 build up
Re: paj1 build up
Mint, thought about using 3.5 pajero intake/radiator plumbing since it's already a north south engine?
Should go hard!
Should go hard!
Re: paj1 build up
Also do you have any info on that engine? Like the year etc?
Reason I ask is my 3.5 runs out of puff at about 5500 rpm yet the rev limiter is at somewhere just over 7000. The cams from the engine you have might be different and might make power higher in the rpm range which I'd like, and drop straight in. I'm tight so don't want to go down the road of aftermarket cams
Re: paj1 build up
Diamante and magna s are 4 cam 2.5 and 3.5
No don't like how the manifold sits and won't have room with the s/c in relation to the throttle body,
Last edited by Crash bandicoot on Mon Jul 17, 2017 6:25 pm, edited 1 time in total.
Re: paj1 build up
dvk-kp wrote:Also do you have any info on that engine? Like the year etc?
I'm not sure rpm limit on the diamante this engine came from is 8500
Re: paj1 build up
No I don't like how the manifold sits and won't have room with the s/c in relation to the throttle body.
Re: paj1 build up
Crash bandicoot wrote:dvk-kp wrote:Also do you have any info on that engine? Like the year etc?
I'm not sure,the rpm limit on the diamante this engine came from is 8500
I'd say it is the cams and ecu tune, but also I found Mitzi's exhaust systems are very restrictive as well, have ya looked at that aspect?
Re: paj1 build up
Cool thanks, will do more research into changing to thos cams. Read a lot on ozzy forums and they always talk about changing cams to Magna/diamanté cams but a lot of what they deal with is sohc and I'm unsure what they are referring to, different spec cars sold to different country's etc.
Yep I've got a good exhaust, made some headers and a full 3" exhaust, also have a k&n air filter and snorkel so I'd say it's breathing as well as it can.
In the mud the drop in power isn't noticeable, revs straight out to rev limit but on the road, under proper load it feels really flat after 5500ish. Noticeable torque drop off.
Thanks for your input, I'll keep researching and stop polluting your build thread!
Re: paj1 build up
dvk-kp wrote:Cool thanks, will do more research into changing to thos cams. Read a lot on ozzy forums and they always talk about changing cams to Magna/diamanté cams but a lot of what they deal with is sohc and I'm unsure what they are referring to, different spec cars sold to different country's etc.
yeah it'll defo be the cams and ecu tune then, probably tuned for low down torque when fitted to the pajero vs top end hp in the diamante etc
Re: paj1 build up
Well now. This crazy arsed plan of fitting the engine and supercharger might actually work
Re: paj1 build up
Have got it to a point i can fire it up and move around the yard.
had a bit of a set back with one of the injector seat seals not doing its job so had to pull intake off again and replace that.
got the alternator re mounted up high again (factory position is down low on the 6g74 block), top rad hose re-directed to clear the cross over intake pipe done ,vacuum lines, throttle linkage, done.
still have to make cover for the Alt to stop the mud/water from splashing on it from bonnet vents, oil catch can, remount battery tray, will make a custom air box for it once the final location for the pro drive style super charger is figured out, for the time being at least i can run it in standard N/A form with the factory 180kw.
tidy the loom up some more where it departs the firewall for the engine sensors.
make up a new tensioner/idler pulley configuration for the multi rib belt to run to incorperate the new position of the alternator and allow for the primary drive for the S/C
Re: paj1 build up
Awesome stuff mate, you don't piss around!
Post a video when ya got it up and running, bet it will be fun even without boost.
Is 180kw at the engine? A factory rating for that engine? And how does that compare to a 3.5 pajero?
Re: paj1 build up
dvk-kp wrote:Awesome stuff mate, you don't piss around!
Tbh i dont know a hell of a lot about this particular engine apart from being from a JDM imported ralliart magna/diamante which differed from the australian assembled magna/diamante, the difference being that the JDM engines run 24 valve four cam setup as apposed to the aussie assembled ones that were 24 valve but ran single cam with forked shape rockers so it could still operate two valves from one cam lobe. the SOHC 24 valve still runs a larger mass head to incorperate the rockers etc were as the DOHC heads are a lower profile not having so many moving parts.
taken from wiki
The Ralliart concept in sedan form only, was a further development of the VR-X and the most powerful Magna ever designed to leverage off Mitsubishi's World Rally Championship exploits.
"The engine was a reworked version of the 6G74 design fitted to Magna Sports and VR-X, but now generating 180 kW thanks to a more aggressive cam profile, modified head and combustion chamber (compression ratio from the Sports/VR-X's 9.0:1 to 9.4:1), remapped ECU and a modified Magna VR-X exhaust system –"
I think the standard 6g74 produced in aussie is some where in the vicinity of 150-160kw and yes both measured at the flywheel.
So it would seem its not just the cam duration and ecu tune but also significantly more head work aswell.
Re: paj1 build up
Thanks for the info, will have to see if I can track down one of thos cars for parts.
Keep up the good work. Trucks looking really good!
Re: paj1 build up
Well, the moment a few of you have been waiting for, got it out on the road today for a shake down,
I cant tell you what speed i got up to being on a public road but it hit the open road limit in second gear and the torque curve is massive, just pulled and pulled all the way up to 7200 on 33x 12.5 tires. I need a new tacho'
and yes the video is deliberate to avoid the identifying the road etc
the video cant do that exhaust note justice either, music to my ears. lol
Re: paj1 build up
Awesome stuff! Looks like it goes really well. Love how far into the red line it revs!
Re: paj1 build up
dvk-kp wrote:Awesome stuff! Looks like it goes really well. Love how far into the red line it revs!
That's not even the limit on that engine either. Lol redline on the original dash that the motor came from was 8500 lol.
Re: paj1 build up
Crash bandicoot wrote:dvk-kp wrote:Awesome stuff! Looks like it goes really well. Love how far into the red line it revs!
Holy shit! That's really singing. Can't wait to hear it wide open in the mud! Keep thos tyres nice and clear
- Crawlerer79
Re: paj1 build up
Ya mind chucking in a link to the video as well as just embedding it... our computers pretty clapped out and can't get it to even show up Cheers
'Lando' - 1994 V8 Disco
Re: paj1 build up
Crawlerer79 wrote:Ya mind chucking in a link to the video as well as just embedding it... our computers pretty clapped out and can't get it to even show up Cheers
https://youtu.be/UFukT6kqY_g
Re: paj1 build up
So after hoofing around the last couple of days had a couple of things crop up.
#1 once up to temp and the fans turned on the engine almost stalled at idle, so had to wire up the auxillary idle control valve up manually to a relay that was turned on when the fans turn on. havent figured out why the computer isnt operating it.
#2 i didnt allow for enough flex in the intake pipe where it connects to the AFM and when ya stand on the gas the engine pulls/flex's so hard on its mounts that it dislodged the steel intake pipe from the afm joiner on a couple of occasions so cut the pipe and added a 70mm silicone joiner to allow more flex.
Apart from that it goes well.
Re: paj1 build up
well after a few weeks took it for a round trip 140km's today with trailer on and it would seem the trans doesn't seem to like the extra power too much, about half way home the A/T temp light came on so pulled over and flicked the fans on manual with the trans in neutral to chill it back down (the A/C core is now the A/T cooler infront of the radiator) but had an inkling something wasn't right as generally it would pass on the heat to the engine radiator and that would be running warmer too but it wasn't (engine didn't go over 87degrees the whole trip).
popped the bonnet and put my hand down behind the grill onto the trans cooler and it was pretty much stone cold.
so i have some investigation to do, apparently the trans cooler bypass valve is operated by two signals, a second temp sender on the engine aswell as a trans temp sender so either the bypass valve is stuck shut or i have a damaged sender.
Re: paj1 build up
Nice work. & you have given me the incentive to build my own winch bar... only started welding a week ago..
Re: paj1 build up
finally.......got some safari springs fitted in the rear of the paj.
along with a ball joint flip and an eye'O'meter camber shim and steering realignment till i get to town to get it done properly
if any one wants some Lwb springs to lift the back of there swb i have a set spare.
in other news brought this little 12v ride on jeep thing for my son, that lasted half a day before it got retro fitted with a car battery.
Re: paj1 build up
nothing jeep about that fella .... ..see your pic doing the rounds , this copy off aussie site......
famous..........................................
v8 tj...luvs the gas......
Re: paj1 build up
yeti wrote:nothing jeep about that fella .... ..see your pic doing the rounds , this copy off aussie site......
yep seen it on a montero /pajero site in canada and another couple of places in europe too . lol
Re: paj1 build up
got sick of looking at the munted rear bumper so doing something about it. not much to write home about really, just one big 3mm plate jigsaw puzzle in the proccess of gettin tacked together, Kind of design as I go style this one, no real plan as such,
....it will have notches built in for the high lift to slot into for jacking thou.....not that my 40" jack is long enough to actually lift the truck's rear wheels off the ground after the lift went in.
Re: paj1 build up
don't do to good of a job... you may inspire me to do mine...
Re: paj1 build up
Frankenstein of geometry
Ran outta gas for the welder so out with the trusty flux core. beats having to clean the steel up before welding, just hit it with the grinder and flap disc afterwards
Users browsing this forum: No registered users and 18 guests
