85 Range Rover parts
TOYRANGE
Postby TOYRANGE » Mon Jul 05, 2004 5:03 pm
5 speed box $500
Transfer box$500
Front drive shaft$100
Rear drive shaft$100
Complete Rear diff$400
Complete Front diff$400
16" 3spoke wheels with 205 tyres ,needs paint$600
Flywheel$150
Clutch$100
3.5 engine with one head removed needs rebuild$200
3.5 engine complete condition unknown$300
Altenator$60
Starter $40
Full exhaust System$50
Radiator$100
Air cond crap$50
Roof racks$100
Im out in West Auckland
Rangerat
Postby Rangerat » Tue Jul 06, 2004 1:22 pm
Hi
What ratio is the diff? and how many splines on the axles?
Rat
TOYRANGE
Postby TOYRANGE » Tue Jul 06, 2004 4:03 pm
Im in the process of pulling it all out so il let you know once ive done it.How do you get the front axles out??,Im going to run a toyota v8/supra 5 speed combo so it isn't goin to drive the front axle,ive been told that you can remove the front axles and head and the front hub will hold the drive flanges etc on.Is this true?
De-Ranged
Postby De-Ranged » Tue Jul 06, 2004 9:46 pm
You have to take the swivel hub off to get all the axle out
You could run it without the axle but... the bearing is lubed by the oil in the axle so you would have to make a plate to cover the hub end where the axle cap is and one for the diff head and fill it up to the level, just thinking about it I'd overfull it as the axles would carry oil from the diff out as they spun, so I'd over full it to make up for that
I'd be interested in what bellhousing / addapter plate setup you use on this as I'm considering the same in another project
Cheers Reece
Cheers Reece
De Ranged Engineering
027 541 8794
TOYRANGE
Postby TOYRANGE » Wed Jul 07, 2004 10:29 am
Cheers, I Think I'll leave the front axles and diff head in there and pull it all outnext year when i change the front suspension.For the toyota v8 setup theres 3options I know of,That guy in waihi makes a bellhousing that will bolt the v8 to the box or you can find an adaptor plate or my friend who does the coversion alot takes the auto bellhousing has it cut and machined and welded to the gearbox cut and machined bellhousing.
Darren
Users browsing this forum: No registered users and 6 guests
