So if you were looking at a diesel Rangie with a cooked motor what would you look at for a repower?
Im waiting on a confirmation of year/model.
Motor conversions - Rangie
- Disco-Gibbo
- Winch master
Re: Motor conversions - Rangie
Firstly, changing from diesel to a petrol is quite involved & not recommended on a cost/ effort basis.
Options:-
1. If the Rangie is a Classic & it was mine I'd replace it with another 200 or 300tdi Diesel (what ever was in it originally).
2. If it's a P38 I'd replace it also (probably the BMW motor)
3. If you don't want to do No. 1 - I'll buy the truck from you as is!
4. If it's the later L322 model, then get it rebuilt
Any of the motor options above can be tuned up safely ie remove ERG, add larger turbo & inter-cooler , but usually compromises longevity if you re-map/chip for more fuel to any extent.
Options:-
classic rangie, there are a number of options.
if an earlier one with the 727, the V8 options are limitless.
200-300tdi manual or auto are a go, just you can not keep your v8 auto is that's what your starting with.
if your lucky to have an LT95 then also look at Isuzu 4bd1 or better 4bb1, auto is not an option with these
By BMW? i assume you mean the TD5, which actually has nothing to do with BMW. its an option, auto or manual.
p38, you can do all of the above but with the diffs on the other side?? the 4.6 is better since it has the bigger lock up GB, you can bolt a puma to this.
look at aschofts, they have a puma 110 to auto kit using the p38 GB, you can just pick the parts from that. chip the puma and new ecu for the box she would bloody fly
your only limited by imagination and cash
I think he's referring to the 2.5l BMW diesel motor that was available in the P38 DSE.
If its a RRC it could also have been fitted with the Italian VM diesel from the factory.
Yeah that Chrysler 727 transmission fitted to early V8s has a very good reputation for strength. ie the one they used before the BMW/ZF 4-speed.
Yheres a rangie in marton with a mitsi canter truck motor n box.. pto too.
4D56? By all accounts they're a torque monster, with reliability to boot.
I wouldn't go with an Isuzu four pot, because they're just a carbon copy of the Cummins 4BT.
I found the 300tdi exceptionally economical and reliable. If it was a series or early 110/90 with a tired two point five in it, I have found the Nissan LD28t to be very suited to that platform. Really nice torque spread, Insanely reliable and revvy enough to allow you to still run 4.7 diff gears, which makes a huge difference off-road.
But personally, for a Range Rover, I don't think an LD would work too well in terms of weight distribution. The 3.5 weighs 150kg, IMO that is one of the reasons the RRC platform works so well offroad. Unless you loaded up the rear cargo area with tools and spare parts and extra fuel, water etc, the weight distribution would become unbalanced. So for a range rover, in my opinion, the answer is a direct injection,light, reliable 4 cylinder diesel... 300tdi or Nissan BD30 at a stretch. But if you want to keep it all Rover, very hard to beat the 300tdi. 195lb/ft of torque at f@@k all over idle speed will piss all over the 3.5 V8 any day of the week. And 3pg in a full time 4wd that weighs almost 2.5 tonn? You can't beat that.
lax2wlg wrote:4D56? By all accounts they're a torque monster, with reliability to boot.
HA HA HA, now i really know why every one said just take no notice of what you write
