Do i keep the disco?
Re: Do i keep the disco? Not for much longer
Well the discos days are numbered, going to pick up a 110 flat deck on the weekend and use the 200tdi from the disco in it. I wouldn't mind getting a r380 gearbox, where would i find one here?
Discovery 4bd1t project
what brought on this decision?
Photos of the 110 when you get it please:)
Message a member on here "littlepigzuk" he runs landrover spares up here in Jaffa land, he has a few wagons out back he is wreaking he may have one
If it helps I take a small truck home (Napier) every couple of weeks so I could cart it for ya
BlakeNZ wrote:what brought on this decision?
Need a ute, cant fit much in the back of the disco
De-Ranged wrote:Message a member on here "littlepigzuk" he runs landrover spares up here in Jaffa land, he has a few wagons out back he is wreaking he may have one
Sweet will send him a pm
Just bought a 4jb1t so may use that instead of the 200tdi in the 110
the R380 will not bolt up to the 200tdi.
the isuzu is a good donk but its a lot of work, i mean how much of the isuzu are you going to use and how much LR stuff are you going to use? box TF case etc
Have a look on http://www.aulro.com/afvb/
A good bunch of guys... and alot of info on the Isuzu conversion
85County wrote:the R380 will not bolt up to the 200tdi.
Its a pretty easy conversion compared to some other engine swaps I have done befor, just going to fit the engine at this stage, will look to upgrade the gearbox later, hard to beat $250 for a complete 4jb1t
De-Ranged wrote:Have a look on http://www.aulro.com/afvb/
Cheers, have done a bit of reading about the isuzu engines lately, I think the 4jb1t offers the best balance overall for power/economy/reliability/parts availability/tuning potential
Nah, waste of time stuffing round trying to match Isuzu to LR transmission. You'l move everything, cut everything and fab everything (eng mounts, radiator, trans tunnel, fire wall, trans mounts, bell housing, clutch, drive shafts and so on) and then wish you had the Isuzu gear ratios etc to suit the engine. 300tdi for all of the reliability, tuning,parts etc and it bolts to a R380 which is geared for it, and you probably only need to source an off the shelf g.box X member and blaze on some engine mounts.
300tdi can be had for nix
Just sayin
Just sayin
DieselBoy wrote:Nah, waste of time stuffing round trying to match Isuzu to LR transmission. You'l move everything, cut everything and fab everything (eng mounts, radiator, trans tunnel, fire wall, trans mounts, bell housing, clutch, drive shafts and so on) and then wish you had the Isuzu gear ratios etc to suit the engine. 300tdi for all of the reliability, tuning,parts etc and it bolts to a R380 which is geared for it, and you probably only need to source an off the shelf g.box X member and blaze on some engine mounts.
Just sayin
The only thing that needs fabricating is the adapter and engine mounts. Gearbox will stay exactly where it is. I'm on my way home with it now. Will start a new thread and put up some pics
What is it abou land rovers? Own 4 of the things now, the green 2 door 200tdi is gone but have 2 manual 300tdi discos, the 110 project and a v8 disco parts/body donor
Users browsing this forum: No registered users and 33 guests
