Broken Transfer Box on Mt Greenland
muddy
Postby muddy » Thu Nov 03, 2016 3:19 pm
Almost to the top and bent the rear trailing arm climbing the last rock step. Collateral damage the whole engine/gearbox got shoved forward - broken mounts and fan disintegrated on front crossmember after chopping a power steering hose but radiator OK. No drive at rear - thought it was a diff pinion, but removed rear driveshaft and drove out in FWD. Turns out the rear output shaft has sheared.
So if anyone has a spare Landrover LT230 transfer Box lying around - I'm after parts....
NJV6
Re: Broken Transfer Box on Mt Greenland
Postby NJV6 » Thu Nov 03, 2016 7:10 pm
Mt Greenland strikes again :lol:
How was the horrible blue goop?
muddy
Postby muddy » Fri Nov 04, 2016 7:23 am
Blue mudstone section was driveable for some but most needed a winch or snatch. Bog was driveable if you got the line right. Even the rock step where the break happened was driveable but easier in a LWB. It was a pretty dry day
lax2wlg
Postby lax2wlg » Fri Nov 04, 2016 10:02 pm
Ahh bugger that's a lot of carnage... if I was nearby I'd offer to help with the repairs. Mind if I ask what axles your running in that beast?
muddy
Postby muddy » Sat Nov 05, 2016 6:15 am
Safari axles - cos I had a set and heard horror stories about how weak the Landrover diffs were. Surprisingly easy to fit - but I do have a mate with an engineering business. LSD front and ARB rear diffs. 4.1 ratio diffs are perfect with 35in tyres too. I expected the diff pinion or UJ to break with the extreme driveshaft angle but I guess the LR output shaft was the weakest point...
lokrite
Postby lokrite » Sat Nov 05, 2016 11:41 am
Got a whole 95 runner I used to launch boat you can have with bits for 800 but its in welly
muddy
Postby muddy » Sat Nov 05, 2016 2:24 pm
Thanks for the offer - but I found a gearbox locally.
4x4man
Postby 4x4man » Mon Nov 07, 2016 10:33 pm
hello dumb question, but where is mt greenland ??
wjw
Postby wjw » Tue Nov 08, 2016 6:08 am
4x4man wrote:hello dumb question, but where is mt greenland ??
Driving South on SH6 into Ross, at the dog leg you go straight on past the pub (instead of right) and keep going..... if memory serves correctly, been 8 years since I went through there.
Who knew Prados could fly?
4x4man
Postby 4x4man » Tue Nov 08, 2016 9:30 am
thanks very much,thought it was somewhere around there :)
is the track difficult ? could a semi standard ute do some of the track ?
muddy
Postby muddy » Tue Nov 08, 2016 10:22 am
You could certainly make a start, but unlikely to get past the "Blue mudstone" section which is VERY slippery and quite rutted, so requires pretty good articulation and/or lockers and/or winch with good tyres. Also be careful of washouts on the sides of the track. I'd strongly suggest 2 trucks so you have help on hand and don't get too ambitious. Even turning around can be difficult...
NJV6
Postby NJV6 » Tue Nov 08, 2016 2:36 pm
You also need to have absolutely no compassion for your vehicles paint work, the gorse is pretty full on.
drive it ...
Postby drive it ... » Tue Nov 08, 2016 4:40 pm
Gorse is a bit better since sinda went through a month or so back and did some pruning and dug some water cut outs. Big thumbs up to them.
Still "west coast scratchy" track though.
4x4man
Postby 4x4man » Tue Nov 08, 2016 8:55 pm
okay cool thanks might have look sometime
4x4man
Postby 4x4man » Wed Nov 09, 2016 9:33 am
has anyone got more pictures of what the track is like ??
wjw
Postby wjw » Wed Nov 09, 2016 11:27 am
I had to reverse round one zig and two zags to be able to turn round, many moons ago in my prado, pre mods... 31's no lockers etc
