Swivel Ball fluid/seals
Posted: Sun Sep 09, 2018 6:18 pm
Ok so a bit of googling just confused me more. In landrover wisdom of over engineering everything correct me if I'm wrong but it seems to me a series 1 disco has oil in the diff, grease in the bearings, and oil again in the swivel/cv?! Or is the whole lot oil?
Previous experience tells me that oil weeping from the swivel means the axle seal is gone and a nightmare of a job to get at clean replace and regrease everything. But maybe not so bad if it's just the ball seal..that said I haven't looked how to replace that yet haha. I've always just cut the seal and put the join at the top with a bit of rtv sealant in the join but maybe not an option if it has to hold oil rather than just keeping dirt and water out like other makes of axle.
The swivels are coated in the usual 5mm layer of greasy dirt mud mixture so hard to see exactly if it does have the fill/level/drain plugs
