Posting this on behalf so any would be appreciated.
old bloke doing up an 85 rangie vogue, have had a lot of rovers and other 4x4 but want some advice on this one ie; when she is running in neutral there is a slight noise similar to a thrust bearing (worn) this stops when you push the clutch in.
the only other problem is noisy gearbox in 1,2, and slight in 3, goes away in 4th and 5th, this vehicle had been badly neglected by previous owner, the clutch and gearbox operation is excellent.
thanks for your time
Mike
