80 Series Swivel housing rear seal - Greasing leaking onto ball
Has anyone had any luck with cutting the gasket and rubber seal to do this without dismantling the hub?
Who knew Prados could fly?
Re: 80 Series Swivel housing rear seal - Greasing leaking onto ball
Usually when they are leaking it is the inner axle oil seal leaking diff oil into the swivel ball diluting the grease. Personally I would strip and inspect it just to check.
*sigh* It was only two years ago (20,000km's ish) that the we did all the seals, new axles and CV's ... no offroading since then either
Seems to be a regular issue. I guess doing those seals would make sense as it will all be apart.
- mudlva
wjw wrote:*sigh* It was only two years ago (20,000km's ish) that the we did all the seals, new axles and CV's ... no offroading since then either
Didnt you have a bronze bush failure whiles back??
That would of stuffed ya inner seal. Beat you didnt replace it when doing the bush ah??
mudlva wrote:wjw wrote:*sigh* It was only two years ago (20,000km's ish) that the we did all the seals, new axles and CV's ... no offroading since then either
That wasnt me, but we did replace everything that wears when we did the front end as the oil leak was driving me nuts all OEM too
- mudlva
wjw wrote:mudlva wrote:wjw wrote:*sigh* It was only two years ago (20,000km's ish) that the we did all the seals, new axles and CV's ... no offroading since then either
K... my bad
So either a bent axle housing or half shaft.
I know its hard to do but try blueing the new seal.
If everything is nice and straight then it may be a case of reshimming the king pins to raise or lower the half axle relasionship to center the axle on to the seal properly.
That is the purpose of the shims
K... my bad
tbh from what I've read it's likely because I'm part time 4wd. The vibration of the axles in the seal deforms it over time. That problem doesnt happen when its rotating. I guess two years/20K must be that time.
Anyone used Marlin Axle Seals on their 80?
- mudlva
Havent seen those seals looks interesting..
Humm re parttime issue. Same set up as 40. 60 and 70 series and they dont leak...
Doneno otherwise
Doneno otherwise
- Bush Crasher
if it is only the grease and not a mixture of grease and oil then you may be good with just replacing the dust seal which can be done without dismantling. make a clear cut and make sure cut is upside when fitted.
when oily then proceed as suggested by the other guys. make sure to use only original parts, I fitted aftermarket seal which lasted not as far as getting home
Users browsing this forum: No registered users and 21 guests
