cool__bananas wrote:you should be on the rev limiter from the bottom thats what i do anyway
yep thats the one they put the limiters are there for a reason
turoa wrote:cool__bananas wrote:you should be on the rev limiter from the bottom thats what i do anyway
na should be in such a high gear that it struggles to get to the rev limiter
Jerry wrote:Time for an update I spose
Have found another LJ71 body the same shape with a good roof and doors and a fresh wiring loom, so I'm looking at doing a body swop, the only problem is that the new body is a lovely poo brown colour , but that can be repainted.
Picking this up next weekend hopefully.... helpers welcome...as the donor body needs to be disconnected and unbolted and moved onto a trailer....will put up a post next week advising where and when (beer will be supplied).
we have rallwoods booked that weekend hopefully I can last the whole weekend without drowning or breakin itJerry wrote:i might try and pospone to the week after...
haynzy wrote:we have rallwoods booked that weekend hopefully I can last the whole weekend without drowning or breakin itJerry wrote:i might try and pospone to the week after...
wgtnnewbie wrote:haynzy wrote:we have rallwoods booked that weekend hopefully I can last the whole weekend without drowning or breakin itJerry wrote:i might try and pospone to the week after...
sure you're not going in to try your hole in the river again..........
Jerry wrote:Update: picking up the new doner body this sat, plan at this stage is to unbolt it, chuck it on a trailer and drop off to Graeme's workshop in Petone, will probably need a hand unbolting the doner and lifting onto the trailer and taking back off.
Will be another working day/bbq after this to do the bodyswop (leaving the tricky electrical connections etc for graeme to sort out, will look at a day to get this prepped for painting as well. winch needs to come off the pos so it can be stripped and checked also the winch bar needs to be strengthened (sadams one cracked in in the same place).
This sat's task however is to get the doner body, Usual refreshments will be supplied PM Me for the address
Jerry wrote:doors fked, roof fked, pillars fked, wiring loom fked...
Users browsing this forum: Google [Bot] and 15 guests
