Longfield Supersets for LJ7x and KZJ7x Series
suzolla
Postby suzolla » Mon Jul 16, 2012 11:43 pm
Following on from my 70 Series axle lengths thread http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=31346
How much interest would there be in me getting some Longfield Supersets to suit. Just need to remember that you also need to either run their hub gears or drive flanges. The drive flanges make the hub assembly much stronger as they have 6 drive pins extra to the 6 taper lock bolts.
Note that the pre 1990 FJ70 are the same as FJ40.
Now sorted see following post.
Tim
suzolla
Re: Longfield Supersets for LJ7x and KZJ7x Series
Postby suzolla » Wed Nov 07, 2012 9:52 pm
Hi,
Following on from above I ordered and have now got custom length axles from Longfield to suit the LJ7x and KZJ7x. The earlier model ones should be a direct fit as the oil seal diameter (33mm) should be the same as Hilux and earlier FJ Cruisers, for the later model ones the oil seal ID is 35mm, so the oil seal wil need to be changed to suit the longfield axles, the OD of both seals is 50mm. The larger seals are the same as the 80 Series seals.
For the earlier ones that don't need seals Cost is $1350 plus post which is about $50.
For the later ones that need different seal Cost is $1350 plus post which is about $50.
You will just need to get early model seals.
The toyota seal no is 90310-35010.
For the longfield warranty need to run Hub Gears ($225) or Drive Flanges ($300)
PM me if interested
Tim
suzolla
Postby suzolla » Sat Nov 17, 2012 8:31 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Nov 27, 2012 12:15 pm
Bump.
See first post
PM me if interested
Tim
suzolla
Postby suzolla » Thu Dec 06, 2012 12:27 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Sun Dec 16, 2012 8:55 am
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Thu Jan 17, 2013 10:01 pm
Bump.
See Second post
PM me if interested
Tim
imsohi
Postby imsohi » Fri Jan 18, 2013 5:37 am
Hey tim will be looking at getting a set some stage this year most likly with drive flanges i will let you know
suzolla
Postby suzolla » Mon Jan 28, 2013 12:07 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Feb 08, 2013 9:34 am
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Sat Feb 16, 2013 2:36 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Sun Mar 10, 2013 8:48 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Wed Apr 10, 2013 12:01 am
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Sat Apr 27, 2013 9:19 am
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Sat May 11, 2013 4:59 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Jun 07, 2013 8:15 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Tue Jun 25, 2013 5:22 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Wed Jul 10, 2013 11:57 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Fri Aug 02, 2013 9:17 pm
Bump.
See Second post
PM me if interested
Tim
suzolla
Postby suzolla » Mon Aug 26, 2013 1:24 pm
Bump.
See Second post
PM me if interested
Tim
1 Left
suzolla
Postby suzolla » Mon Sep 16, 2013 4:39 pm
Bump.
See Second post
PM me if interested
Tim
1 Left
suzolla
Postby suzolla » Sun Dec 15, 2013 9:04 am
GOT SOME MORE
Bump.
See Second post
PM me if interested
Tim
tallsam66
Postby tallsam66 » Wed Feb 26, 2014 9:02 pm
You still got some of these ?
suzolla
Postby suzolla » Wed Feb 26, 2014 10:28 pm
Hi Trevor,
Yes still got some.
Tim
callum007
Postby callum007 » Mon Mar 10, 2014 6:36 am
Hi Tim,
You got any Nitro gears at the moment, heard you may?
suzolla
Postby suzolla » Mon Mar 10, 2014 9:08 am
Got some 4.88's in a few days, what ratio are you after.
Tim
callum007
Postby callum007 » Mon Mar 10, 2014 6:43 pm
bloody 4.56... would need the fitting kit with flange etc too.
suzolla
Postby suzolla » Mon Mar 10, 2014 7:41 pm
only 4.56 i have is a Yukon Hi Pinion
Tim
PigFmr
Postby PigFmr » Mon Mar 10, 2014 8:11 pm
pm sent
callum007
Postby callum007 » Mon Mar 10, 2014 10:19 pm
All Good Tim, they cheap enough to bring over, you got any tg solid pinion spacer kits?
Users browsing this forum: No registered users and 4 guests
