anyone know of anyone that can sell me a hilux rear axel bearing puller? to be used in a press.
worked in a toyota dealership and had one for general use. now in need of one.
Rear axel bearing puller?? hilux, hilux surf
Re: Rear axel bearing puller?? hilux, hilux surf
I made one with some heavy wall 50 mm box and plate .Works a treat and a good test for my welding .Where are you
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
im down in invercargill
Out of interest can you post a pic of this said device?? DId a set for a mate the other day, and they were a real shit to remove. be interested to see what you made..
- ClassicCruiserSpares
- Sausage Shack
I made one up out of an old hilux diff housing. I cut the axle tube off by the nugget then got some plate bored a hole in the end so the axle can fit through it then welded it to the tube.
All you need to do is bolt the axle tube to the backing plate bolts then put it in the press and push the axle out. All done in the mater of minutes.
Here is a vid ....Shows all the things that people do to stuff them....
Also he makes up a tool....
I did the one in my playdoh....Cant remember using anything special....
I have a feeling I collapsed the bearing so it slid off the axle and then carefully cut the bearing inner ring and its retainer then sharp smack with a hammer and it split off....
The outer race I pressed out....
Its an easy job, but there is a couple of tricks that make it easier
after you have removed the spring clip ontop of the compression collar, gently tap the bearing housing down on the bearing, you can normally get it so its flush with the top of the bearing
now grind out one side of the compression ring, I use the end of the grinding disk to do this you'll grind into part of the old bearing... you don't want to grind all the way through, you'll know you've gone far enough when as you grind up and down the side of the collar a blue band appears in the middle
This does two things weakens the collar and expands it
Then biff it in the press and it pops off
If the collar has been heated to install (see below) and you just try and press it off it galls the axle shaft and I've had it bend the tabs on the axle tub and snap studs!
When I put the new collar on I heat it bright red drop it over and give it a tap with a bit of pipe, I know alot of people just hammer them down with a bit of pipe... but I've seen them fail at speedway as a result of that trick.... interestingly never seen or heard of a failure on a truck with this trick, but as I'm often doing this for other people I do it the best way
The heat expands the collar so it just about falls into place then it cools and clamps to the axle
I'll get a pic of my press tool for ya its just nocked up out of scrap and an old axle tube
I'd offer to make you one but I'm not flying down to bluff for at least a couple of months
Cheers Reece
Cheers Reece
- Sausage Shack
I couldnt watch anymore than 2mins of that vid, he was so god damm boring to listen too
ClassicCruiserSpares wrote:I couldnt watch anymore than 2mins of that vid, he was so god damm boring to listen too
Yes I was going to post a warning... I just quickly scanned thru to the good bits...
mine is like that guys .I watched his boring video but made the tool and learned how to do it .Was easy with 80 ton press .Left the tool at local garage he thought it was brilliant and has used it heaps. Not a bad job for cow farmer
