hey guys im looking to raise my hilux 4 inches from standard and i was just wondering what the cheapest way is?
thanks
whats the cheapest way to raise a LN85 hilux 4 inchs
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
31 maxxis buckshots
Re: whats the cheapest way to raise a LN85 hilux 4 inchs
Put a jack under it
Bit more specifics maybe,
Care how it handles?
Wanting to keep it road legal?
You could do a suspension lift with box section steel like this guy:
Or do a body lift with box section like this guy:
Therefore, when you're on a tight budget and you need to get stuff done, box section is your friend
Toyhatsu Bitsalux
- Crash bandicoot
hmmm that second one might need a cert plate for that bumper with the frontal impact laws.
Don't care to much about the handling but road legal would be good haha
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
- tomsoffroad
- Flopsie
2" body lift. 2" leaves. Cert. Still close on 2g if you do all the work
Why do you need to raise it? Tyre clearance? If so just borrow an angle grinder, a hammer and some vice grips. Spend $20 on grinding discs and paint. Maybe even splash out $25 on some sikaflex and a bunnings caulking gun to use as a "flexable bog" to fill up some of the gaps after you cut and fold a new curve on your guard. Pretty ghetto though.
Also you can gain about 20mm of "tyre to rear of front guard/firewall" clearance for free by unbolting the front axle from the leaves, redrilling the locating pin hole in the spring perch (about 20mm back) and bolting it all together again. Note that you will possibly loose some right hand lock and will definitely need to mess around with drag link adjustment. I guess the torque arm thing to the top of the diff will need some kind of mod/adjustment as well. This is much less ghetto.
the answer to your question would be dependant on what your trying to achieve by lifting it up 4 inches, is it to fit and clear large tyres, get some long travel suspension flex going or just the look cool factor to get big tyres on it would also include some major drive train and/or gearing changes to get the torque to turn them adequately and compensate for the tall gearing and reducing ratios in the diffs usually makes them weaker so you could have to look at upgrading to bigger/stronger diffs as well to eliminate breakages and retain reliability, if you want long travel articulation that usually sacrifice's road manners so you could end up with a truck that has awesome capability offroad but is a dangerous dog on road that that has pretty scary bodyroll and steering geometry and it gets to the stage you don't enjoy or want to drive it anymore, if you just want the look cool factor then its just that
if i just did a 2 inch body lift, what tyres would fit on it then?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
sg8380 wrote:if i just did a 2 inch body lift, what tyres would fit on it then?
round black ones.
you have to realize that's a fairly vague question. Are your springs sagged to hell? Can you tolerate a little rubbage at lock and bump?
I had 33's on my RN36 with no body lift, not bad springs and 8.5" rims with a big offset (big offset makes it worse as the radius of the arc is bigger). They rubbed a bit at full bump, but not too bad. Then I moved the axle forward (as above) and it was all good. Your truck is a different model obviously, but from what I have seen I would expect you will get 33's on with out much work.
Can you borrow a 33 wheel/tyre for a day to fit it and have a measure up? That's where I would start. You may find a body lift doesn't help much (as they usually rub at the back of the guard)
My rzn60 surf just has 50mm body lift, the front springs are standard but not saggy, I have 33s on 15x8 -19 rims rubs a wee bit at full compression and lock.
Thanks Stu
Thanks Stu
- tomsoffroad
- Flopsie
bigstu wrote:My rzn60 surf just has 50mm body lift, the front springs are standard but not saggy, I have 33s on 15x8 -19 rims rubs a wee bit at full compression and lock.
Thanks Stu
Rzn60........ nice
Users browsing this forum: No registered users and 18 guests
