Hi I'm looking for a transfer case for my mums 85 60 series, she seems to have done something to low range any help appreciated.
Cheers Aston
60 series transfer case wanted
Re: 60 series transfer case wanted
70 series split cases the same?
If so i have one.
If so i have one.
Only difference is the idler shaft size and manual or vacuum activated 4wd selector, early 60s had 34mm shaft and manual linkages, while the later 60s and 70s had 38mm idler shafts and vac operated 4wd selector. I believe 85 was the changeover year as well.
Didn't barbie drive a jeep??
Hi thanks for the reply it's button activated 4wd so dose that make it vacuum? It's hooked up to an H2 if that helps,and I believe it that some 70 series do match up il have to measure the shaft, I'm not very familiar with toyota stuff so appreciate any help
Might be worth having a look at the original first to see if you can figure out the problem? If you describe the problem I'm sure someone on here should be able to point you in the right direction.
Can swap all the cases over as long as you swap the whole case front and rear. Can even swap in a full manual case, just the button wont work anymore and you will need to use the lever.
