On the look out for either a good or a buggered unit. Mine is toast so wanting a good one o replace it.
OR, a stuffed unit to chop up and convert to a cable operation.
Prado rear E Locker actuator wanted
Re: Prado rear E Locker actuator wanted
Good luck they are pretty rare....
I plan to go air operated when mine packs up.... some info on the net about it.... Mainly for the 80 series and tacoma's in the states.
Do you have any good links, I need to do this to mine.
Matt
Matt
luxtoy wrote:Do you have any good links, I need to do this to mine.
Matt
Was going to try something like this...
http://www.pirate4x4.com/forum/toyota-t ... rsion.html
But have the actuator directly drive the shaft... not via rods...
Like this
http://forum.difflock.com/viewtopic.php?t=67105
I was looking to use a second hand brake lever or a quad bike hand brake with a lock out to run mine as a cable locker.
I don't have a suitable air source to run an air ram.
I was given one of these...
Should do the trick.....
Calvin
Calvin
kbushnz wrote:I was given one of these...
Calvin
Send it down to me?
It would do the trick.
juz wrote:Pmd ya Smurf
cheers mate
