Hi,
i lifted my 1992 hilux surf with 80 series rear springs an ive got about 3.5" of lift in the rear and about 2 in the front with torsion bars and im needing some new shocks.
Im in a tight budget and am wondering if these will do the trick http://www.trademe.co.nz/motors/car-parts-accessories/other-accessories/auction-1030697057.htm
rear shocks for lifted ln130
Re: rear shocks for lifted ln130
your wanting to put them in the rear or front? 80 series rears fit in the rear, standard 2" lift in surf, 2" lifted 4" lift in surf.
with a 4" lift in rear what you doing about the panhard? have you lifted the brake balancer in the rear? is the brake hose long enough?
I need new shocks for the rear the stock ones keep bottoming out, I'm just wondering if those shocks on that TradeMe link will fit? (http://www.trademe.co.nz/motors/car-par%20...%20697057.htm with my 3.5" lift in the back.
The panhard rod in on the list to do I'm going to weld myself a drop bracket.
I'm sure about the brake hose it seems to be fine there's a bit of slack but i haven't taken it offroad since the lift.
it says they are fronts for a 60 or 70 cruiser. 80 series rears fit, don't know about others.Attica wrote:http://www.trademe.co.nz/motors/car-par ... 697057.htm
maybe http://www.trademe.co.nz/motors/car-par ... 451582.htm
someone else might know better.
Thanks man!
- tomsoffroad
- Flopsie
I can sell you Amada shocks to suit for $140 each incl gst if you keen?
Users browsing this forum: No registered users and 16 guests
