My Hilux has an epic amount of play in the steering and it is mostly coming from the link arm. As I am using it I have not pulled it apart but what do i need to fix it? It looks like there is a part pressed into the pitman arm - that piece is moving in the arm. Do i need a new pitman to get the ball joint or is it a replaceable part?
Then there is the movement in the link arm joint itself where it meets the pitman arm, its adjusted as far in as I can so need replaced. rebuild or replace?
LN106 Steering play
LN106 Steering play
Re: LN106 Steering play
Time for cross over steer for the farm hack?
Think they are adjustable pull the split pin and turn the very end with a coin
Cheers, I have got it fixed. Rebuilt both ends and new knobby for pitman arm. Getting pitman arm off was hardest, had to take sterring box out and hit it with a fbh. Much nicer to drive in the paddocks now.
Didn't even know you could get those drag link joint rebuild kits! I'll be sure to remember that when mine needs replacing.
Toyhatsu Bitsalux
Users browsing this forum: No registered users and 4 guests
