97 surf
97 surf
Postby coxsy » Thu Dec 14, 2017 7:49 pm
was going to stick rock sliders on a this surf ,
problem being less than 6 mm between body an chassis do these thing settle on their mounts ,
escape plan lift the bodhy with packers 10 mm ,
resort to weld 12 plate to chassis mount slides on them
can't use c mounts as no room for nuts they will,be hard on against the floor that will be square one again
mudsurfv6
Re: 97 surf
Postby mudsurfv6 » Thu Dec 14, 2017 8:05 pm
coxsy wrote:problem being less than 6 mm between body an chassis do these thing settle on their mounts
my 96 has a 50mm body lift and has 60mm between body and chassis. so would have had 10mm.
Re: 97 surf
Postby coxsy » Mon Dec 18, 2017 4:24 pm
going to make custom c mounts for it not my usual u mounts
Users browsing this forum: No registered users and 30 guests
