Hi guys I have a stock 92 swb 1.6 16v that I have recently done a 3inch suspension lift and also front strut top hat flip and ended up with extreme front positive camber .guessing about 3-4 degrees I have just put in some camber bolts I brought off eBay which give a max of 1.75 + or - camber and obviously still not enough adjustment to sort out my problem .
Any tips or ideas on getting more adjustment ?
Possibly run 2 extra camber bolts up front 1 up top and also on bottom?
Your help would be much appreciated!!
Marcus
3inch lift camber bolts not enough help!
Re: 3inch lift camber bolts not enough help!
On mine the knuckle hit the strut where the top bolt goes through not allowing it to go in any further. I filed the knuckle away and got heaps of camber change after that.
I took a die grinder to the top bolt hole that the shock bolts to.
I found camber bolts were a pain at best.
For off road/race stuff the camber bolts tend to work loose, I've had to weld a few in place. I'd die grind, fit a couple of heavy washers, set it then spot weld the washers in place to hold it.
Definitely don't fit 2 bolts on each side...
DEATH_INC wrote:For off road/race stuff the camber bolts tend to work loose, I've had to weld a few in place. I'd die grind, fit a couple of heavy washers, set it then spot weld the washers in place to hold it.
Grind some slots in the shock hole and tack the washers in place ya recon? Will this pass wof?
Mine did. Paint everything black and a decent coating of mud. Straight round to VTNZ. Trust me....
Cheers MIKE
Cheers MIKE
That's this w.e sorted then!
Cheers mate!
Cheers mate!
Didn't get the chance this w.e , before I go ahead with it has anyone done anything different?
The calmini 3" kit has longer lower arms to correct camber.
I did camber bolts and slotted bottom hole so still adjustable to get spot on
poor little suzuki
Users browsing this forum: No registered users and 12 guests
