3inch lift camber bolts not enough help!
Posted: Thu Feb 20, 2014 8:08 pm
by Marculo
Hi guys I have a stock 92 swb 1.6 16v that I have recently done a 3inch suspension lift and also front strut top hat flip and ended up with extreme front positive camber .guessing about 3-4 degrees I have just put in some camber bolts I brought off eBay which give a max of 1.75 + or - camber and obviously still not enough adjustment to sort out my problem .
Any tips or ideas on getting more adjustment ?
Possibly run 2 extra camber bolts up front 1 up top and also on bottom?
Your help would be much appreciated!!
Marcus
Re: 3inch lift camber bolts not enough help!
Posted: Fri Feb 21, 2014 7:52 am
by churchill
On mine the knuckle hit the strut where the top bolt goes through not allowing it to go in any further. I filed the knuckle away and got heaps of camber change after that.
Posted: Fri Feb 21, 2014 7:55 am
by Weemsy
I took a die grinder to the top bolt hole that the shock bolts to.
I found camber bolts were a pain at best.
Posted: Fri Feb 21, 2014 10:32 am
by DEATH_INC
For off road/race stuff the camber bolts tend to work loose, I've had to weld a few in place. I'd die grind, fit a couple of heavy washers, set it then spot weld the washers in place to hold it.
Definitely don't fit 2 bolts on each side...
Posted: Fri Feb 21, 2014 5:03 pm
by Marculo
DEATH_INC wrote:For off road/race stuff the camber bolts tend to work loose, I've had to weld a few in place. I'd die grind, fit a couple of heavy washers, set it then spot weld the washers in place to hold it.
Grind some slots in the shock hole and tack the washers in place ya recon? Will this pass wof?
Posted: Fri Feb 21, 2014 5:27 pm
by ONOescudo
Mine did. Paint everything black and a decent coating of mud. Straight round to VTNZ. Trust me....
Cheers MIKE
Posted: Fri Feb 21, 2014 5:30 pm
by Marculo
That's this w.e sorted then!
Cheers mate!
Posted: Sun Feb 23, 2014 9:38 pm
by Marculo
Didn't get the chance this w.e , before I go ahead with it has anyone done anything different?
Posted: Mon Feb 24, 2014 8:39 am
by zukmeista
The calmini 3" kit has longer lower arms to correct camber.
Posted: Fri Mar 14, 2014 11:44 pm
by 1kz_surf
I did camber bolts and slotted bottom hole so still adjustable to get spot on
