This is my Zook that I have been working on over the last few years.
2" body lift
3" suspension lift
2" shock spacers and hat flip
15/8 rims with 30" tyres
the frog escudo
- Campbell.s
- Driver/Navigator
Re: the frog escudo
Awesome !! Were bots in nz are ya?
Wot mods have you done so far?
- Campbell.s
- Driver/Navigator
Re: the frog escudo
Just outside chch, so far I've rebuilt the motor and front and rear diffs, lock rite front and rear, front diff is steel, 3 inch suspension lift, winch bar with a 9500lb runva, rock sliders, LED light bar etc just got to get the top coat on and wiring up dual batteries and some kind of rear bar that will house the high lift jack.
Re: the frog escudo
What 3" suspension you running?.
Any pics of front bar as I'm building mine now and starting on my rear bar soon to take the high lift jack across the rear horizontaly.
- Campbell.s
- Driver/Navigator
Re: the frog escudo
FTS lift kit not sure how it'll go seems to hard at the moment but will soon find out. Winch was made by ORE member loppee in rolly, top bloke and makes a damn good bar. Would love to see what your rear bar turns out like.
Re: the frog escudo
How have you mounted the front bar to the chassis?
Awesome looking bar!
- Campbell.s
- Driver/Navigator
Re: the frog escudo
Has brackets that bolt to two factory holes where the bumper mounts to I believe on the side and then drill a third through the front, then simply bolt the bar to the brackets, I'm adding in another to tie it back to that round bar that goes across the front of the chassis.
Re: the frog escudo
What color u painting ur Zook?
Be good to see it finished.
- Campbell.s
- Driver/Navigator
Re: the frog escudo
The factory metalic blue, will put some pics up when it's done in a couple of weeks
Re: the frog escudo
Quick question do you need a cert for a 2" body lift?
Re: the frog escudo
kiers117 wrote:Quick question do you need a cert for a 2" body lift?
Yes you do, especially if you want to pass a WOF.
Re: the frog escudo
Nice escudo mate where about are you? Sure I seen this driving around Tauranga this arvo, can't be too many escudos with twin snorkels around haha
Re: the frog escudo
3VILC wrote:Nice escudo mate where about are you? Sure I seen this driving around Tauranga this arvo, can't be too many escudos with twin snorkels around haha
Yep I'm in welcome bay.
If your on Facebook search
Hayden Holmberg to get in touch
