Hi, just wondering what the advantages/advantages of running 15x7 or 15x8 rims. i am currently running 31x10.5/15 on 15x7 and wondering
if there is any advantage of upgrading to 15x8. what is everyone running on there sj's ? also what are poeple using for flares ?
SJ413 rims
Re: SJ413 rims
15x8 would be a downgrade with 31's as they won't hold the bead as well at low pressures. I have used reinforced rubber sheet cut into strips for flares, works well and a lot cheaper than the flash moulded ones from repco and won't try and rip off your guards like bunnings garden edging does when it gets hit.
Re: SJ413 rims
even with tubes in the tyres ? where abouts did you get that rubber from ?
Re: SJ413 rims
I got it from Para Rubber their website says there is a couple of stores in Auckland. Tubes will help but I have run 31's on 8" rims with tubes before and it isn't hard to knock a bead off although I did run quite low pressures (5-8psi)
Users browsing this forum: No registered users and 11 guests
