Ok so i have a 2011 suzuki vitara with a J24a engine.
Its been over heated and suspected cracked head.
The car is a gas guzzeler and i would like to convert it to diesel.
I understand they came out with diesels from factory with what i think where renault or something similar.
Anyone had any experience with this model ?
Will any other bellhousing bolt up ?
Would love a 2.8 isuzu anr TD27 in there
Diesel engine options for a 2011 vitara
- Rotazuk
Re: Diesel engine options for a 2011 vitara
No expert on the gv's but this is my opinion .
The model you have did have the renault 1.9 diesel but only in a manual . From all accounts it was not the best engine they had and not very powerful . I have been unable to find an automatic box that would bolt up to it , I want a diesel auto . So looked into all the boxes and came up empty .
The early gv autos were a versoin of the AW4 which is resonably common and in a few toyotas and jeeps etc . I expect with reasonable differences but maybe interchangeable . I suspect the later gv are a Aw5 box but not confirmed this .
The issue you will have in swapping out the engine for a different one will be the canbus and the info that is shared all around . My idea of swapping a manual for an auto was ok as it looks like no info from the manual was shared on the canbus etc.
Off the top of my head I would say it would be cheaper to fix the 2.4 or replace it with another 2.4 and sell it and then find a diesel . However if you do persue it I would be interested to hear what you find out about it , I would like to do something similar and end up with a reasonable diesel and auto in a gen 3 GV .
Chris
Chris
If you can get a TD42 into that Navara of yours you should be able to get one into that Zook as well mate
derk wrote:If you can get a TD42 into that Navara of yours you should be able to get one into that Zook as well mate
With Hilux diffs?
That would be interesting.
But just not practicall in such a refinned vehicle.
Users browsing this forum: No registered users and 34 guests
