Has anyone changed the oil sump gasket on a g16b without pulling the engine? Looks it should come out by dropping the diff out the way?
Sump leak g16b
Re: Sump leak g16b
Yes I have now done it twice drop the diff then undo all the sump bolts turn steering one way to get drag link out the way and fight and move in a way where you can get it around the drag link.
If you don't succeed. Try again with "more revs".
https://youtu.be/d9o8YZLmOPs?t=1m34s
- Winch master
Re: Sump leak g16b
deadduck wrote:Yes I have now done it twice drop the diff then undo all the sump bolts turn steering one way to get drag link out the way and fight and move in a way where you can get it around the drag link.
Did you drop the pick up at the same time? I have it off but it looks like it's gonna be an ass to get back around the pickup and in without disturbing the RTV bead?
Re: Sump leak g16b
No I had it all on the pick up isnt the problem its the drag link that takes some rtv i got sick of rtv so i put a cork gasket
- Winch master
Re: Sump leak g16b
deadduck wrote:No I had it all on the pick up isnt the problem its the drag link that takes some rtv i got sick of rtv so i put a cork gasket
I got it in there and it hasn't leaked overnight. every other person online has said the cork gaskets are shit, has it sorted your leak?
Re: Sump leak g16b
I had to put a new sump on my engine hit the front diff but it hasent leaked since using the cork gasket
Users browsing this forum: No registered users and 28 guests
