SJ413 diff swap to Vitara
Posted: Mon Aug 21, 2017 8:24 pm
by Santas60
can someone tell me whether a vitara diff will fit into a SJ413 axle? (excuse the poor terminology lol)
just looking into regearing options for my SJ,
Re: SJ413 diff swap to Vitara
Posted: Mon Aug 21, 2017 11:43 pm
by UBZ
The G16 vitara front diff will fit into the sj413 & samurai housing . From memeroy they are 22spline , so to fit to the rear of a SJ you need to change the side gears to 26spline .
Also the vitara Carrier is alloy and a lot weaker than the SJ steel carrier .
The best option is to use the vitara ring and pinion and rebuild them into the SJ steel carrier with the right side gears for front and rear
Posted: Tue Aug 22, 2017 7:08 am
by Sausager
Some of the vitara diffs are 26 spline and so are a direct fit. But you'll just end up breaking the aluminium housing, so swapping the ring and pinion over is the go.
Have a read here:
http://suzukiclubuk.co.uk/diy/16-transm ... conversion
Posted: Wed Aug 23, 2017 1:12 pm
by Santas60
great, thanks for this. helpful as
